Team Associated 1/8 scale Truggy Info and Tips >
Old 10-26-2011, 02:21 PM
  #3421
It could be the case that shock oil somehow works differently from brand to brand. So, maybe going from 32wt to 30wt losi oil has different effects on a particular vehicle compared with going from 32wt to 30wt associated oil.
Maybe the thing to do is match oil brands to vehicle brand. So, losi vehicles run losi oil, xray vehicles run xray oil, etc. Im beginning to think that a lot of buggy/truggy problems are being caused by mixing brands. I'm going to try a lot of setup changes this weekend and check out my lap times.
071crazy is offline
Old 10-26-2011, 02:29 PM
  #3422
tc5 man's Avatar
True diffrent brands do seem to have thicker shock than others im using losi shock oil and its somewhat thick so it likely whould not have the same effects maybe. Ive used associated shock oil and diff oil its defietly thinner than losi oils for sure.
But a test like your saying whould be great.
tc5 man is offline
Old 10-26-2011, 02:44 PM
  #3423
Suspended
Trader Rating: 202 (96%+)
are all parts the same from rc8t to rc8t CE??? also what rx pack works well?
inferno13 is offline
Old 10-26-2011, 02:55 PM
  #3424
tc5 man's Avatar
All the supension ball links are the same the supension arms, the top steering rack cover is on the "rc8tce" the one on the rc8t is plastic i believe . The only diffrences on the CE is the alum shocks towers, steering rack cover and the alum supension blocks pretty much all the weak areas are covered now.
Expect for the plastic rear camber links which do tend to flex i boiled them bastards.
As for a Rx pack ive used a 1500 mah nimh battery before i converted i forgot what manf it is sorry.
Did you get the rc8tce ?
tc5 man is offline
Old 10-26-2011, 02:58 PM
  #3425
Suspended
as far as rx pack i was kinda lookin for hump or stick? will a losi lipo rx pack fit?
yes, i should have it saturday, i actually could not decide on rc8tce or serpent, so i bought both and will keep the one i like...LOL
Old 10-26-2011, 03:09 PM
  #3426
tc5 man's Avatar
Oh ok yea its a hump pack the battery is up front on the rc8tce.
Dam you got both not sure which one you will like lol but the rc8tce likes to be driven hard to a limit. But you will have more support for the rc8tce at most tracks.
But il say one thing the serpent parts are quality.
tc5 man is offline
Old 10-26-2011, 03:12 PM
  #3427
Suspended
thanks, well if they like it or not, they will be driven hard!! we will find out what one likes it more
Old 10-26-2011, 03:14 PM
  #3428
tc5 man's Avatar
lol yea .
There is one guy at my track that runs a "serpent truggy" and i was watching it around the track to me it looks like it fishtails a lot on the rear end that might be the setup though who knows.
But the rc8tce is planted though il tell you that .
tc5 man is offline
Old 10-26-2011, 03:25 PM
  #3429
Suspended
lol yea .
it should be.....the rc8tce is the heaviest truggy out right now at 4300grams. serpent is the lightest at 3800grams, so i got the heaviest and lightest..
I must say i do like a little weight on my rides, just fits my driving style better.
Old 10-26-2011, 03:39 PM
  #3430
tc5 man's Avatar
The rc8tce might be but if you pick it up off the ground it does not feel like it but wheels/tires make a big diffrence in that like the aka tires. Does not drive like it ethier not being bias. Hell i think my rc8tce converted ways about 10 pounds i think with a soft pack lipo the rc8tce is a pound less.
I like more weight espially on a dry/dusty track its great !
A light weight truggy in my opinion which ive driven before is hard to drive on a track like that.
tc5 man is offline
Old 10-26-2011, 03:55 PM
  #3431
Suspended
im all nitro, i have no use for electric stuff. anything i have questions about will be nitro specific
Old 10-27-2011, 04:29 PM
  #3432
Trader Rating: 17 (100%+)
F.Y.I. Thunder Tiger part# PD1861 heatsink brake discs are the same as the Associated 89123 discs used on the truggy, buggy and SC8. They are $15.99 at Amain. Amain# TTRPD1861. The Associated list for $24.99. I would run the Avid discs but the last time I checked they were out of stock. So you can save a few bucks with the TT's. I have a hard time spending $25.00 on two brake discs, just does'nt seem wright.
reeltech is offline
Old 10-30-2011, 05:53 PM
  #3433
Suspended
what weight diff oil are most useing? 7-7-7? 5-5-5?
Old 10-30-2011, 06:49 PM
  #3434
tc5 man's Avatar
When i ran my as nitro it was 7,7,3 at first than 7,7,5 seemed to worked really good. If you want more on power steering or more torque out of corners than try 7,10,5 or 3k in the rear.
I run the same diff setup except 10k in the center on my converted rc8tce.
tc5 man is offline
Old 10-30-2011, 06:59 PM
  #3435
Suspended
thanks, i read this whole thread today! have a bad headach now!! i have read everything from 5-3-5, 5-5-5, 7-7-7, 7-5-7, 7-3-7, 7-10-7, 7-10-5, 7-7-3, 7-10-3, 5-7-5, REALLY!, this is not real helpful at all. but so far 7-7-7 or 7-5-7 seems to be the most talked about. but did not see what track suface to use the differnt set ups on.
