Team Associated 1/8 scale Truggy Info and Tips >
Old 08-02-2011, 01:01 PM
  #3286
Maxthepersonz's Avatar
Trader Rating: 20 (100%+)
Anyone?
Maxthepersonz is offline
Old 08-02-2011, 03:25 PM
  #3287
NitroFreakManHo's Avatar
Are they new? Or are they used ? Also, is everything shimmed according to the manual ? If they're used and shimmed properly, then you may have a bad gear in your diff.
If it's new, check the shims, something may be wrong. Maybe others will chime in. From my experience, the AE diffs are incredibly strong(strongest) if shimmed properly.
NitroFreakManHo is offline
Old 08-02-2011, 03:59 PM
  #3288
Its about 5 gallons old. I got a new gear set even though none of them looked bad.. its all shimmed correctly so the gears will hopefully fix it.
Old 08-02-2011, 05:17 PM
  #3289
R/C Lidz's Avatar
Trader Rating: 60 (100%+)
I'm sure the new gears will fix it. Had the same thing happen on my buggy
R/C Lidz is offline
Old 08-02-2011, 09:19 PM
  #3290
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Hey guys. I've got a brand new Jconcepts body for sale for an RC8TCE.
http://www.rctech.net/forum/r-c-item...ml#post9475064
Brad
Brad S. is offline
Old 08-05-2011, 05:10 AM
  #3291
I just installed the FT Machined Steering Blocks and the FT Machined Rear Hub Carriers on a RC8T CE. Should the turnbuckle lengths be the same as the stock setting? The angles do not look correct now.
BGspillz is offline
Old 08-05-2011, 08:08 PM
  #3292
tc5 man's Avatar
i forgot to ask since i changed my caster to "14 degress" do i need to change the kick up from the stock setting 2 degrees ?
tc5 man is offline
Old 08-06-2011, 08:35 AM
  #3293
PTP Racing's Avatar
If you changed the red and blue inserts in the caster block and upper mounting position you have successfully changed your caster. If you change the kickup then you will again change the angle of your caster.
When you changed to 14 you still have to add the kickup to get your actual caster. The values of kickup are written on the A plate.
PTP Racing is offline
Old 08-06-2011, 08:57 AM
  #3294
king revo's Avatar
Trader Rating: 22 (96%+)
Default Uh oh
U just opened a can of worms with that info.. Mass confusion is coming and huge senseless posts to follow about what you said.. Lol you'll see
king revo is offline
Old 08-06-2011, 09:43 AM
  #3295
tc5 man's Avatar
ok i did change to the 14 degrees caster inserts, and placed the cone washers toward the front like the tuning section on the manuel said.
so since your saying i need to change my kickup now on the A plate do i use 2 up or 3 up on the bushings ?
Im using the stock setting for the kickup .
its not the upper pivot inserts i change right im guessing ?
sorry i never tried to change caster really espailly on this truck.
tc5 man is offline
Old 08-06-2011, 01:33 PM
  #3296
cordarrow's Avatar
Trader Rating: 17 (100%+)
Here it comes....
No. Don't change your kick up. Drive it and see if you like the 14 degrees with the A plate right where it is now.
cordarrow is offline
Old 08-06-2011, 01:50 PM
  #3297
PTP Racing's Avatar
LOL
You do NOT need to change kickup after changing caster.
OK here comes the hard part.
Changing kickup changes caster further. When you set caster at 14 your real caster is not 14 but 14 + the kickup angle.
A 1 dot insert in the A plate is 8 degrees kickup. If your running 14 degrees caster and a 1 dot bushing in the A plate you are really running 22 degrees caster.
For the super advanced class you get to add the new B plate...but your not ready yet.
  #3298
cordarrow's Avatar
What PTP was saying here...
...is you add the caster of the inserts (14, 16, 18) to the corresponding number on your A plate (6, 7, 8, 9, 10) to come up with the actual caster you're running. So, say, 14 degree inserts and 8 degree kick up on the A plate gives you 22 degrees of actual caster.
The inserts and the A plate are independent of one another...you may change either one...or both.
Only for reference do you need to add their values together.
  #3299
cordarrow's Avatar
Beat me to it...LOL
Old 08-06-2011, 05:27 PM
  #3300
tc5 man's Avatar
ptp: thanks man sorry im new to the caster/kickup thing, since i barely change it but i want smoother steering so im trying 14 degree caster.
I dint really want to change the kickup anyways if not needed.
cordarrow: thats good yea il just try it as is with the stock settings for the kickup.
tc5 man is offline
