Team Associated 1/8 scale Truggy Info and Tips >
Old 06-04-2011, 04:05 AM
  #3031
truggyup's Avatar
Originally Posted by tc5 man
yea my, track is big no real big though but the layout is techinal i can handle the rear loose somewhat but i dont like it when it rotates to fast . i am going to use the ride height gauge this time insend of doing it by eye.
im still learing the tuning on this truck theres a lot of setttings.
Yep ur 100% on that. I try to use different parts of the suspension to control what i need done. So lets say the track is hooking and i can't rotate the way i would like to well than i go down on the rear ride hight from 43mm to 40-41mm. Seem to work,but if im still having some trouble than i add rear droop from 121mm to 123mm. These are some ez adjustments to make on the fly. Now the front end i really dont touch 38mm r/h 111-113mm droop. my track small, tight, and technical. A big plus we dont have any real big jumps so i can get away with 35wt shock oil front n rear year round.
truggyup is offline
Old 06-05-2011, 04:23 AM
  #3032
jdogger1's Avatar
Cool Ryan Maifield Video
We just posted some new video of Ryan Maifield at www.rcinsider.com from the 2011 ROAR 1:8 Gas Nats...
www.rcinsider.com
jdogger1 is offline
Old 06-05-2011, 06:29 AM
  #3033
emancipation007's Avatar
Kinda green when in comes to racing. Especially outdoors. I was hitting this big jump after along straightaway and the truggy would nose up real bad. Would hit the brake and it wouldn't level off. I have factory setup and couldn't figure it out. Any help I would appreciate.
If you were on the gas in the air it would make the nose go up like that.Let go of the gas before the you get to the ramp of the jump
emancipation007 is offline
Old 06-05-2011, 07:18 AM
  #3034
hyperfuxx's Avatar
Trader Rating: 31 (97%+)
I would lock up the tires and it wouldn't correct itself.
hyperfuxx is offline
Old 06-05-2011, 07:21 AM
  #3035
truggyup's Avatar
Maybe you can try tapping the brake just before the jump. I know too much speed can upset the take off from a jump, because the vehical may bottom out on the takeoff ramp.
truggyup is offline
Old 06-05-2011, 09:25 AM
  #3036
first thing you should check is to make sure u have brakes while on the ground cause if u dont have them there it wont help when ur in the air u may have alot of rear brake and not enough on the front brakes to help it tilt donw so check that also ......and also let go of the throttle as u hit the ramp that helps too ...
BigThyperST is offline
Old 06-05-2011, 09:42 AM
  #3037
truggyup's Avatar
Does anyone have a problem with the rear left camber link inside getting a bend in it. I just put a new set on and it starting to bend again.
truggyup is offline
Old 06-05-2011, 11:06 AM
  #3038
tc5 man's Avatar
thats pretty tricky, acutally to let off a little before you hit the face of the jump you really have to know how much throttle you need to clear the jump before you try that. what i do is hit the jump and let off the throttle a little bit or tap the brake to downside a jump.
it depends on the jump really.
truggyup: i havent, notice any bending in my rear camber link but than again i havnt ran it a whole lot ethier it seems like my front supension arms are bent it looks like i have a lot more camber than i set it at.
tc5 man is offline
Old 06-05-2011, 01:33 PM
  #3039
truggyup's Avatar
Ur right tc5 man i kno just how much throttle I need to clear at my track. Check the c-hub, the holes where the stainless bushing goes reams out fast. The top side is worst than the bottom so it would look like u have camber. I'm thinking about going aluminum.
truggyup is offline
Old 06-05-2011, 03:18 PM
  #3040
tc5 man's Avatar
yea il check that out how can you tell if there wared out really ?
ive only ran the truck five times im using 1- camber on the front.
but with, the wheels off the ground and the tires off it looks like "2- camber or more but i have to see with the tires on and the truck on the ground.
tc5 man is offline
Old 06-05-2011, 03:19 PM
  #3041
Kent Beal's Avatar
Trader Rating: 72 (100%+)
Maifield brings home another nationals win for the RC8T.
Kent Beal is offline
Old 06-05-2011, 03:22 PM
  #3042
tc5 man's Avatar
nice ! looks like losi has been getting wooped in the past national races this year
some guys on here that are losi bias always put down the rc8t.
yet it still wins at every level.
club, pro racing whatever.
maifield and tebo has been kicking tail this year in truggy.
tc5 man is offline
Old 06-05-2011, 04:43 PM
  #3043
R/C Lidz's Avatar
Trader Rating: 58 (100%+)
nice!
who'd he have to punt to get it?
R/C Lidz is offline
Old 06-05-2011, 05:31 PM
  #3044
Trader Rating: 68 (100%+)
He didn't punt anyone. He took the win by a lap.
I run Losi but I don't bash what anyone else decides to drive.
It was a good run for Maefield and he is tough to beat. Congrats
Greg B is offline
Old 06-06-2011, 01:17 AM
  #3045
STEALTH's Avatar
Trader Rating: 21 (100%+)
WOW!
Cool RACING News
Next Page!
STEALTH is offline
