Team Associated 1/8 scale Truggy Info and Tips >
Old 05-29-2011, 08:21 AM
  #3016
tc5 man's Avatar
Originally Posted by rawdawgga
im having a problem with the truggy pushing on power on sweeping turns what can i do to correct this my shocks are 40wt f, 35wt r diffs are 10-10-3 everything else is great. thx for any help
i whould have to say using "10k" on the front can cause that try "7k" in the front diff and try 35w shock oil in the front.
tc5 man is offline
Old 05-29-2011, 09:06 AM
  #3017
Jason_R's Avatar
Personally I like 7-7-7 with 35wt all the way around, but of course track is going to have a lot to do with it.
Jason_R is offline
Old 05-29-2011, 09:10 AM
  #3018
emancipation007's Avatar
Default Try this link it should help you
http://jq-products.com/the-news/43-t.../160-the-guide
emancipation007 is offline
Old 05-29-2011, 09:11 AM
  #3019
R/C Tech Elite Member
Have you tried 35wt in front shock or to play with front toe, ride height and camber?
Sylvain is offline
Old 05-30-2011, 04:12 AM
  #3020
king revo's Avatar
Trader Rating: 22 (96%+)
Default duh
Originally Posted by emancipation007
first of all your on a truggy thread,and second noone cares about a JQueer buggy.
king revo is offline
Old 05-30-2011, 07:46 AM
  #3021
t4ftracer's Avatar
Trader Rating: 73 (100%+)
Check your servo saver tension adjuster.
I can almost guarantee that it has backed off and is too loose causing your on power push. Very common...
t4ftracer is offline
Old 06-01-2011, 07:03 PM
  #3022
hyperfuxx's Avatar
Trader Rating: 32 (97%+)
Default nosing way up on big jumps
Kinda green when in comes to racing. Especially outdoors. I was hitting this big jump after along straightaway and the truggy would nose up real bad. Would hit the brake and it wouldn't level off. I have factory setup and couldn't figure it out. Any help I would appreciate.
hyperfuxx is offline
Old 06-01-2011, 07:57 PM
  #3023
Just built my first truggy last summer. I have a couple races under my belt as well as practices. I noticed it pushes in the corners. I have the stock set up in it. Was wondering if I should go with Shane racer's set up or a different kind of set up. Any advice would be great.
harleyhoots is offline
Old 06-01-2011, 08:02 PM
  #3024
tc5 man's Avatar
i have the same problem but im not sure if it was my truck or the jump that was messed up from rain .
come to find out on one left rear shock my shock bladder had a tear on the top of the bladder .
harley: try 1 to 2 degree negative toe out on the front.
tc5 man is offline
  #3025
Brad S.'s Avatar
Trader Rating: 39 (100%+)
First thing to do, is try 3000 weight rear diff oil. Any setup from Ryan Maifield works well, but 3000 in the rear diff tends to help the truck turn "quicker".
Brad
Brad S. is offline
Old 06-02-2011, 10:42 AM
  #3026
truggyup's Avatar
Originally Posted by tc5 man
truggyup: have you ever tried 7,10,3
midnight: with, the 3k in the rear it rotates quicker and actually feels more like a buggy somewhat. i
it can be somewhat loose though.
grated i havnt tried diffrent oil setups.
Sorry for the delay TC5 Man, "WORKING". OK no never tried 7-10-3. 7-7-7 was ok but 7-7-3 was awsome until the left turn started getting wider. Now I have replaced all front componets, new brakes, and new center shafts. It seems to have worked, but I've changed to many things at once to pin point what fixed the problem. LMAO
truggyup is offline
Old 06-02-2011, 11:08 AM
  #3027
tc5 man's Avatar
no problem, thats good yea i was running "7,10,3 but now im trying" 7,10,5 the more the i drove with 3k in the rear i dint like it as much it rotated to fast and at times the rear end got pretty loose.
tc5 man is offline
Old 06-02-2011, 11:30 AM
  #3028
truggyup's Avatar
no problem thats good yea i was running "7,10,3 but now im trying" 7,10,5 the more the i drove with 3k in the rear i dint like it as much it rotated to fast and at times the rear end got pretty loose.
Yeah I hear ya. I like the loose rear. My home track is tight so it helps me set up for the turns. I have also started to ply wit anti-squat and ride hight. i found more squat more off power steering. Now you loose some on power steering so I decrease the rear ride hight to slow down the rotation. Now the truck feel good again wit the v-spec,but the .25max IDK......
truggyup is offline
Old 06-02-2011, 11:34 AM
  #3029
tc5 man's Avatar
Yeah I hear ya. I like the loose rear. My home track is tight so it helps me set up for the turns. I have also started to ply wit anti-squat and ride hight. i found more squat more off power steering. Now you loose some on power steering so I increase the rear ride hight to slow down the rotation. Now the truck feel good again wit the v-spec,but the .25max IDK......
yea my, track is big no real big though but the layout is techinal i can handle the rear loose somewhat but i dont like it when it rotates to fast . i am going to use the ride height gauge this time insend of doing it by eye.
im still learing the tuning on this truck theres a lot of setttings.
tc5 man is offline
Old 06-02-2011, 04:53 PM
  #3030
The set up info is the same for all cars based on a buggy.Grow up!!!!!!!
