Team Associated 1/8 scale Truggy Info and Tips >
Old 02-13-2011, 07:03 PM
  #2431
Originally Posted by Teufel Racing
you could try running a little less front droop.
Say you normally run a front shock length (droop) of 113mm, try going down to 110 or 111mm and that should help keep the front end from unloading on power. I did that at the last race I was at and it seemed to help, but there could be better solutions to correct that.
Thanks. Ill have to give that a shot.
1sickGT is offline
Old 02-13-2011, 07:42 PM
  #2432
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
sickGT,
No problem man. I only just recently figured that out. Still learning the RC8T and what it likes and doesn't like to be run at. Tried lowering the droop setting on the front pretty much as a last ditch effort on race day. Good thing it worked. I should get more practice in one of these days.
Teufel Racing is offline
Old 02-13-2011, 08:40 PM
  #2433
sickGT,
I didnt realize that it was that bad untill one of the other guys at the track drove it for me.. He told me i needed to make some changes.
Hopefully by making some changes ill be faster next time out.
1sickGT is offline
Old 02-15-2011, 05:34 PM
  #2434
AlanHall's Avatar
Trader Rating: 43 (100%+)
Has brandon or anyone said anything about the arm changes they've done to the buggys being worth a shot on the truck? I have some used arms I've thought about chopping up lol
AlanHall is offline
Old 02-15-2011, 07:59 PM
  #2435
Brandon Melton's Avatar
The thought crossed my mind, but the truck in stock form is IMHO as good or better than any truck, whereas the buggy had a couple improvements it needed on certain types of tracks. It's not as easy as hacking out some riser sections and bolting the shocks in, lots of things as uptravel and droop, leverage, etc.. to try and get right. You would need lower towers first off, just way too many things to try and do as a homemade project. I have no clue as to if AE has any thoughts or plans for this, your guess is as good as mine.
Brandon Melton is offline
Old 02-15-2011, 09:24 PM
  #2436
AlanHall's Avatar
Kool man. I just liked the idea of the new parts making the car more stable. My truck isn't always stable feeling to me. It seems like it wants to over react on uneven bumps and stuff. I've tamed it down some buy thickining up the shock fluids. But its probly just me. Im about two gallons back from not running for like 2 yrs.
AlanHall is offline
Old 02-15-2011, 10:03 PM
  #2437
tc5 man's Avatar
how does the rc8t champ rotate good,ok ,bad into corners ?
and is it pretty stable on a rough track ?
tc5 man is offline
Old 02-16-2011, 09:25 AM
  #2438
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Corners extremely well. I had to dial out some steering. Rotates well and is especially good mid corner to corner exit. I run my truggy mostly at Revelation which is hard packed with a loose top layer and the tire of choice is usually a city block or caliber.
Truggy is good on rough tracks. If you already drive an 1/8 buggy, an 1/8 truggy makes driving so much easier with the stability and added suspension (especially true for rough tracks, but may feel slow and sluggish on smooth technical tracks).
SEF is offline
Old 02-16-2011, 03:46 PM
  #2439
tc5 man's Avatar
so it sounds like the rc8t ce is good on rough bumpy tracks ?
yea i like rotation and good cornering man it defietly sounds like i will like the way it drives .
i like steering just not to twichy or reacting to fast.
ha yea i saw truggys racing on smaller tracks
i, drove a eight-t 1.0 last year first season racing truggy from buggy and like truggy more on a rough track.
tc5 man is offline
Old 02-16-2011, 05:48 PM
  #2440
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
here is a chassis i just got done for a friend of mine.. mr. john young.. start weight is 348.7 grams.. end weight is 290.2 grams.. 58.5 grams lighter.. should help out in low grip conditions also but yet be good in high bite also.. if you have any questions pm me.. jeremy
Attached Thumbnails Team Associated 1/8 scale Truggy Info and Tips-johnny-youngs-rc8t-chassis-003.jpg   Team Associated 1/8 scale Truggy Info and Tips-johnny-youngs-rc8t-chassis-004.jpg
J.Whiting is offline
Old 02-16-2011, 06:26 PM
  #2441
AlanHall's Avatar
Help in low traction cause it flexs?
AlanHall is offline
Old 02-16-2011, 07:01 PM
  #2442
Super Moderator
J.Whiting's Avatar
correct...
Old 02-21-2011, 01:45 PM
  #2443
outoforder's Avatar
Trader Rating: 34 (100%+)
How many ounces do you guys use on a steering servo. Im looking at a 231oz. Servo but don't know if that is enough
outoforder is offline
Old 02-21-2011, 01:46 PM
  #2444
LOL...that is plenty!
bohdi is offline
Old 02-21-2011, 02:01 PM
  #2445
Audiobahnaholic's Avatar
Trader Rating: 44 (96%+)
I run a Savox 1268 on straight lipo.
Audiobahnaholic is offline
