Team Associated 1/8 scale Truggy Info and Tips >
Old 01-22-2011, 11:21 PM
  #2281
RC8tmaniac's Avatar
Originally Posted by dragracechief
Here is a pic of a lightend RC8 chassis, Rc8t would be similar.
thanks. My friend had his chassis lightened in rc8b but it was a bit hmm... too light I think. It was 80g lighter than the standart one.
RC8tmaniac is offline
Old 01-22-2011, 11:54 PM
  #2282
Originally Posted by sriley
Okay guys I need some advice. I'm also getting ready to change my diff and shock fluids. I run at Hobby Hut which tends to be very dry, dusty and slick. I was wondering what diff fluids would be best for this type of track. Also this past season it was really rough towards the end of the season. Last season I started with 7-7-7. Then I changed the rear to 5 to stop the back end from coming around. It seemed to fix the problem. What I'm thinking of doing is 7-10-5. I was thinking of the 10 for the center to stop the front tires from spinning so much. Let me know what you guys think. Thanks.
I'd go with 7-10-3 or 7-10-2. I run at the hut also.
Mark K is offline
Old 01-23-2011, 06:18 AM
  #2283
sriley's Avatar
Trader Rating: 32 (100%+)
Thanks for the diff fluid suggestions.
sriley is offline
Old 01-23-2011, 06:25 AM
  #2284
[QUOTE=BigThyperST;8520932]selling a rc8t ce with a picco 21 evo 3 and 2 hitec servo's ....hs7955tg and hs645mg .......and a bunch of extra parts to go along with it includeing the factory team carbon fiber shock towers and radio tray ........the truck has been raced about a dozen times at 2 tracks one in jersey and in penn. the motor only has about a gallon and half through it , comes with a jammin jp3 pipe , the truck is very clean .....also comes with shock oils and diff fluids , right now the diffs have no fluids in them. truck was taken apart after race season and cleaned .new parts were put on front and rear arms and all the ce parts ...shock towers and front and rear plates and has the new radio tray also comes with 3 sets of tires Ibeam, Gridions and City Blocks plus a custom painted body .......iam looking for $450.00 or best offer .......if interested message me back will pay for shipping and if local will bring to u ....
[/QU
ASKING $450.00 or BEST OFFER
BigThyperST is offline
Old 01-23-2011, 08:31 AM
  #2285
j_blaze14's Avatar
Trader Rating: 34 (100%+)
7,7,7 good traction, 7,5,7 low traction. if its really cold out 5,5,5 or 5,3,5. 10k in the center will make the back come around too fast still. front is spinning cause of too much rear traction with lower oil.
j_blaze14 is offline
Old 01-23-2011, 11:08 AM
  #2286
tc5 man's Avatar
7,5,7, dam 5k in the center diff on a truggy maybe all truggys are diffrent i guess if you seen the track me and sirily and mark k race at 7,10,3 seem to be the setup but i could be wrong .
i know i read the manuel for the rc8t and it said for a bumpy track run 7,10,3 but i guess its just driver prefence.
tc5 man is offline
Old 01-23-2011, 11:29 AM
  #2287
dragracechief's Avatar
Have to agree with J Blaze, in my own limited experiance I didn't like 7-10-5, have found on a good track 7-7-7 works well but if you have low traction 7-5-7 helps a lot, if conditions warrent it I could see 7-3-7 working. I am looking forward to racing season so I can do some more testing on this.
dragracechief is offline
Old 01-23-2011, 11:32 AM
  #2288
tc5 man's Avatar
man, 7k in the rear i know i tried that on my "eight-t 1.0" and it was terrible maybe because i was running 10k in the center though.
oh the track me and mark k and siriley race on when its hot is low traction and dry for sure !
and bumpy .
but all truggys must me diffrent .
tc5 man is offline
Old 01-23-2011, 11:33 AM
  #2289
Marcus Falconie's Avatar
quick vid for you associated truggy guys
+ YouTube Video
Marcus Falconie is offline
Old 01-23-2011, 04:37 PM
  #2290
I can tell ya from my own experience that running 7-7-7 was very hard to drive. When I powered out of the corners, the backend would step out every time. I was new with the truck so I left it alone for a couple of runs figuring that I just had to get used to the truck. After practice and 2 qualifiers, I was having to hard of a time driving it. All I had was 2k, so i put it in the rear diff and went out for the third qualifier and I INSTANTLY felt a difference. The truck was a lot easier to drive (for me) and I could jump on the power sooner at the exit of the corners without the rear end coming around on me at all. Granted, no 2 people will like the same setup, so this is just what I did for my driving style. Since I race at Hobby Hut with sriley that's why I reccomended that diff setup.
Mark K is offline
Old 01-23-2011, 04:51 PM
  #2291
I'ts wierd, I believe every thing you said and have seen others do it, but for me pesonally when I go lower than 7 in the rear or higher than 7 in the center the rear of my truck becomes very loose and I have trouble with it. 7-5-7 made it more controllable, testing to resume in the spring.
Old 01-23-2011, 05:05 PM
  #2292
AlanHall's Avatar
Trader Rating: 43 (100%+)
Yeah don't a lighter fluid in the rear help the rear end come around?
AlanHall is offline
Old 01-23-2011, 05:07 PM
  #2293
tc5 man's Avatar
dragracecheif: heres the track i race at this was during the summer it was hot as hell outside !
and dry.
http://www.youtube.com/watch?v=bx5pf...yer_detailpage
tc5 man is offline
Old 01-23-2011, 05:09 PM
  #2294
tc5 man's Avatar
it makes the rear end rotate better and defietly gives you more grip on a dry surface.
tc5 man is offline
Old 01-23-2011, 05:12 PM
  #2295
AlanHall's Avatar
Wouldn't that mean it's taking some traction away?
AlanHall is offline
