Team Associated 1/8 scale Truggy Info and Tips >
Old 11-10-2010, 11:58 AM
  #1921
mmaattppllaayy's Avatar
Trader Rating: 35 (97%+)
just go on avids bearing website and buy their orings much thicker and stiffer compound than regular orings. They are much easier to put on than the metal rings too. Its like 2.99 for a 4 pack i think. well worth it
mmaattppllaayy is offline
Old 11-10-2010, 12:06 PM
  #1922
Do-Over's Avatar
Shoe goo will work for now but if problem persists, (I have no trouble with this personally) ^this is the fix.
Do-Over is offline
Old 11-10-2010, 01:43 PM
  #1923
AlanHall's Avatar
Trader Rating: 43 (100%+)
is the streering mod the only real change besides bolt on aluminum parts VS the FT kit? im looking for a reason to get rid of the FT and get a CE .. LOL but the steering is the only real thing i can find different.. well and the radio tray...
AlanHall is offline
Old 11-10-2010, 05:01 PM
  #1924
Klink's Avatar
Default Turning on the Rc8t
I haver the RtR Rc8t I have changed the servos to hobbico cs170, Corbon fiber shock towers, .21 reedy motor, Aluminum chassis brace's , Aluminum Shocks, Racers Edge Servo Savers But the Deal pushs when I turn corners I have to let all they way off the gas and then it dont really tune any way what should I do to help this thanks Guys
Klink is offline
Old 11-10-2010, 08:53 PM
  #1925
gholt13's Avatar
try going down on your caster
gholt13 is offline
Old 11-11-2010, 01:52 AM
  #1926
mgtmadness2007's Avatar
is the servo saver set loose.
mgtmadness2007 is offline
Old 11-11-2010, 09:25 AM
  #1927
chevydc44's Avatar
Trader Rating: 35 (100%+)
does anybody know how i can make the truck lighter i picked up my friends mbx6t and it's alot lighter i have the rc8tce
chevydc44 is offline
Old 11-11-2010, 09:31 AM
  #1928
Do-Over's Avatar
Aluminum outdrives, titanium screws and links, milling the chassis if you have access to a machine shop. I've drove the mugen and mine and while lighter is faster in the right hands it's also twitchy to drive in mine.
Do-Over is offline
Old 11-11-2010, 09:33 AM
  #1929
Do-Over's Avatar
+1, also toe and shock wt. (RTR comes with 50wt., and 0 front toe)
Do-Over is offline
Old 11-11-2010, 09:43 AM
  #1930
Klink's Avatar
Default what is a good set up
Just going to put in differnt shock and diff oils what is a good starting point and what toe should i run thanksi
Klink is offline
Old 11-11-2010, 09:54 AM
  #1931
Do-Over's Avatar
ShaneRacers setup is what I use. It calls for 35wt all around with silver springs, 7 front, 8.5 center, and 7 rear. 2* of toe out.
Actually just PM me your e-mail and I'll send you the setup. You really need to do the whole thing to make it work together. You don't have to do it all at once you can see what each thing affects doing 1 at a time.
Do-Over is offline
Old 11-11-2010, 06:59 PM
  #1932
AlanHall's Avatar
so its correct? should i just keep it? or is the ce different
AlanHall is offline
Old 11-11-2010, 07:35 PM
  #1933
Scott_Mantis's Avatar
Trader Rating: 15 (100%+)
The only other difference i seen between the two, apart from what you had mentioned (Alloy towers, Steering setup) is they run a narrower Hub, and the Jconcepts wing/body... hope that helps..
Scott_Mantis is offline
Old 11-11-2010, 07:38 PM
  #1934
j_blaze14's Avatar
Trader Rating: 34 (100%+)
Originally Posted by sriley
I had it happen to me once with about 5 seconds before the race started. I think Avid sells an o-ring that takes the place of the ring. Or you could just go to a hardware store and see what o-ring they have.
done it, works great. lowe's orings.
j_blaze14 is offline
Old 11-12-2010, 03:10 AM
  #1935
also different geometry as the rear tower has more shock loacation like the front and more camber locations.
I will probably switch to RC8B and RC8T CE if I decide not to switch brands.
