engine help
engine help
I have a ae.15 engine from an rc10gt2 and my brother turned the idle screw all the way in, so i was wondering if anyone knew the factory setting for the idle screw. How many turns out is it from all the way screwed in
thanks in advance
D.Lasoski20
thanks in advance
D.Lasoski20
or, just try starting it, turning it half a turn each time, until it starts then fine tune it.
Suspended
the IDLE Screw only adjust carb opening when at idle, more open, higher idle, less open lower ilde. closed no idle and motor stalls.
if he turned the IDLE screw in when you start it, it should idle quite high and may even engauge the clutch shoes if idled up enough.
if he adjusted the LSN, or the HSN then it will need to be retuned.
the stcok settings typically varry from one milll to another.
