OS .21 V-spec Cluth Setup on Losi 8ight?
24 gram flywheel with 2 green 2 gold springs and top that off with kingheadz 7075 shoes and you have a perfect clutch.
yea i would stick with a stock clutch. other wise you have to either 1) shim the crap outta behind the flywheel, or 2) use a kingheadz mount and reverse it which will move the motor forward and change the handling.
personally i feel the losi clutch setup is the best thing to hit 1/8th scale ever lol. so easy to work on and the kingheadz 7075's make it last forever. and the enlarged inner bearing is just awesome.
