Like Tree23Likes
Kyosho ST-RR
    Hide Wikipost
Old 10-19-2017, 10:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho ST-RR
Last edit by: tobamiester
Current running upgrades/Mods people are doing to this truck late 2016/early 2017.
-Chassis Options
m2c2850 KYOSHO STRR EVO WEIGHT FOWARD TRUGGY
-Engine Mount Option
IFW102 - Blue narrower Mount. Allows you to put Lock Nuts on top of screws that hold the Mount plates in.
Agama motor mount AGM6206
-For MP9 Knuckle conversion
Kyosho IF419 MP9 Knuckles
Kyosho IFW436 16degree Hub Carrier
Kyosho IF420 Knuckle Arm Collar (slightly thinner than STRR one)
Kyosho IF467 Long King Pin
-Strengthening upgrades
King Headz KP-360-BLK Front Torque Arm
King Headz KP-372RR-BLK Rear Torque Arm (extended chassis)
King Headz KP-300LB-BLK Lower Front Holder B
King Headz KP-300UL-BLK Front Upper Holder L
King Headz KP-329 Rear Brace Mount
IS157 Hardened Diff Case from Psycho Kruiser
IGW002GM Alum Rear Hubs
HB Outdrives #67197
-Replacing C-Clip Hinge Pins on Inner Susp Holder
HPI 109848 Hing Pins
Racers Edge/KFactory RCEK8034 Pins (Very hard to find)
or
Replace complete A/B/C/D Blocks with:
*M2C m2c2510 KYOSHO ST-RR/ EVO REAR TOE BLOCK
*M2C m2c2520 KYOSHO STRR EVO TRUGGY FRONT LOWER ANTIDIVER KIT
-Servo Saver Mod
IFW450 MP9 SS Alum Upper Arm
IF417 MP9 SS Lower Assembly
(See http://www.rctech.net/forum/showpost...postcount=4112 for full pics and description).
-Performance Updates
IFW327BL Blue Narrow Hexes (typically run on front).
-Bodies Options
RC8T Bulldog Body (discontinued late 2016).
Print Wikipost
Old 04-28-2010, 07:48 PM
  #751
smokinu's Avatar
Trader Rating: 83 (99%+)
Originally Posted by Frank L
Man marcus Losi style clutch, Losi air filter that K car is turning into a Losi a little bit at a time...
ahaha, actually its turning into an odonnell car since i am switching at the end of nor-cal.
smokinu is offline
Old 05-04-2010, 04:15 PM
  #752
BIG RE's Avatar
Trader Rating: 33 (100%+)
PINIONS!!!!We got some in for you guys.
http://www.amainhobbies.com/product_...ion-Gear-ST-RR
BIG RE is offline
Old 05-09-2010, 01:51 PM
  #753
Hi guys...at 30 May he have our first National Truggy race and i am prepared for this race...now i will do a total rebuild at my st-rr...
At the track that we will race i have race again one time but with diffenent jumps and layout and i finish 2nd ... my set up is 7/10/3 at diffs and i remember that with this set up at this track i loose time at some very tight corners because i have not so good steering ..
What diff oils you suggest me?my mechanic said to move at 7/15/3 so to have less power in front and more power at rear so to turn more easy ..
the track is this
at the last foto is the three tight corners that i loose a lot of time ... the track also has a very good grip
i am waiting suggestions
the_winner is offline
Old 05-09-2010, 10:21 PM
  #754
KWT-NITRO's Avatar
hello,
i think i might help because my STRR has tons of steering, whats your ride height and droop numbers??
this is my set-up
diff oils, 7K front, 10K center, 2K rear
front:
camber: 2
toe out: 3
droop: 118
ride height: 35
shock oil: Ultimate 60 = associated 50
spring: lime
and NO sway bar installed
Rear
camber: 3
toe in: 2.5
kick up: 3
droop: 123
ride height: 38
shock oil: ultimate 60 = associated 50
spring: lime
sway bar: 3mm in
try it and tell me what you think
KWT-NITRO is offline
Old 05-10-2010, 06:38 AM
  #755
Originally Posted by KWT-NITRO
hello,
this is my set-up
front:
camber: 2
toe out: 3
droop: 118
ride height: 35
spring: lime
Rear
camber: 3
toe in: 2.5
kick up: 3
droop: 123
ride height: 38
spring: lime
sway bar: 3mm in
thanks Ali
my set up is something like yours
Diffs: 7/10/3 kyosho oils
front
camber: 2
toe out: 1.5
droop 117
shock oil : 500(kyosho oil)
spring: sky ble(Medium to hard the new springs) with 8mm preload
sway bar: stock 0mm in
Rear
camber:2.5
toe in: 2.5
anti squat:3
droop 127mm
shock oil 550 kyosho
spring lime with 10mm clip
sway bar stock 3mm in
sorry ride height i dont measure it
Old 05-10-2010, 11:28 AM
  #756
KWT-NITRO's Avatar
hello,
you better start mesuring ride height, its very important and you will notice how the car reacts differently when you change the RH.
anyways, dial in more droop up front like 118 or 119, increase the toe out to 2.5 or 3 and try running without the front sway bar.
why this amount of droop at the rear of your truck?? 127mm is alot IMHO
for ride height, make sure you have at least 2mm lower front, i run with 3mm lower front, it helps alot in turnning.
just try those small changes and tell us what you think. also the 2K oil in the rear will free up the rearend a bit and gives you more turn-in.
cheers
Ali
Old 05-10-2010, 03:35 PM
  #757
hello,
cheers
Ali
thanks Ali again..
you measure the RH from the ground to the skid plates?or it doesnt matter if i have skid plates?
with 2k oil rear it will lock up my rear end it will not free up...anyway i will try your small suggestions
Old 05-11-2010, 01:23 AM
  #758
KWT-NITRO's Avatar
Originally Posted by the_winner
thanks Ali again..
from ground to lowest end of the chassis, even if you have skidplates you can do the ride height. lets say the skid plate is 4mm and you need a 35mm front ride height, with skid plates, you should have 31mm, just do the math, you get it ??
i use a normal school rouler to do my ride height.
how come going from 3K to 2K will lock the rear diff??
cheers
Ali
Old 05-23-2010, 10:15 AM
  #759
Hi guys today we had the 5th Truggy Masters here in Greece ...far the way the best race i have race... the car awesome (thanks KWT NITRO) ...at the Final we have rain..at the start a little bit rain but at the mid of the race a lot of rain... I finish first at Level B drivers and 2nd at the Final ranking ...
i will post pics soon...
Old 05-23-2010, 10:22 PM
  #760
KWT-NITRO's Avatar
WOOHOO , congrats on the win and the great result man
happy that i could help
cheers
Ali
Old 05-24-2010, 04:47 AM
  #761
some fotos
3 Kyosho St-rr at the podium
Kyosho St-rr/Novarossi Plus 4 1st and 2nd place
Old 05-24-2010, 01:09 PM
  #762
The next time you will not be so lucky .... cheers ...
aiamec is offline
Old 06-02-2010, 09:14 AM
  #763
XEXEXE !!!!
guys what servo you will recommend me??
I am between, Hitec 7954SH,Team Orion 1409, AE 1015...
i have the ace 1015 and after 13 races it makes some problems but now is ok.... i dont know which servo to buy or to continue play with the crazy servo?
Old 06-02-2010, 03:56 PM
  #764
KWT-NITRO's Avatar
hello,
throttle or steering??
i run savox, same as team orion, savox 1256 or team orion 2015 for steering, 20KGs and .15s, 2 seasons hard driving on buggy and then truggy with zero issues. for throttle, savox 1258 or team orion 1409, 12KGs(savox) 14KGs(Orion) and .08s (Savox) .09 (Orion) , super fast and torquy enough to stop the beast.
cheers
Ali
Old 06-02-2010, 04:38 PM
  #765
thanks ali...
for steering...
The hitec that i looking is 25kg and 0.15 same as orion and savox but i race all the time with the 1015 and i fear that the 0.15 will be slow...
so you suggest me 25kg at the steering??
i thinking about the 1409 or for the hitec 7954SH....
Also something else i strip for second time my front ring/ pinion(the first was some weeks before but after one year of racing) this time was after one week after a big race and i found that the inside bearing of the pinion is without the teflon shield so i think this is the reason that i strip the front ring pinion...
this time i am thinking to buy the Hot Bodies ring pinions
