Like Tree23Likes
Kyosho ST-RR
    Hide Wikipost
Old 10-19-2017, 10:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho ST-RR
Last edit by: tobamiester
Current running upgrades/Mods people are doing to this truck late 2016/early 2017.
-Chassis Options
m2c2850 KYOSHO STRR EVO WEIGHT FOWARD TRUGGY
-Engine Mount Option
IFW102 - Blue narrower Mount. Allows you to put Lock Nuts on top of screws that hold the Mount plates in.
Agama motor mount AGM6206
-For MP9 Knuckle conversion
Kyosho IF419 MP9 Knuckles
Kyosho IFW436 16degree Hub Carrier
Kyosho IF420 Knuckle Arm Collar (slightly thinner than STRR one)
Kyosho IF467 Long King Pin
-Strengthening upgrades
King Headz KP-360-BLK Front Torque Arm
King Headz KP-372RR-BLK Rear Torque Arm (extended chassis)
King Headz KP-300LB-BLK Lower Front Holder B
King Headz KP-300UL-BLK Front Upper Holder L
King Headz KP-329 Rear Brace Mount
IS157 Hardened Diff Case from Psycho Kruiser
IGW002GM Alum Rear Hubs
HB Outdrives #67197
-Replacing C-Clip Hinge Pins on Inner Susp Holder
HPI 109848 Hing Pins
Racers Edge/KFactory RCEK8034 Pins (Very hard to find)
or
Replace complete A/B/C/D Blocks with:
*M2C m2c2510 KYOSHO ST-RR/ EVO REAR TOE BLOCK
*M2C m2c2520 KYOSHO STRR EVO TRUGGY FRONT LOWER ANTIDIVER KIT
-Servo Saver Mod
IFW450 MP9 SS Alum Upper Arm
IF417 MP9 SS Lower Assembly
(See http://www.rctech.net/forum/showpost...postcount=4112 for full pics and description).
-Performance Updates
IFW327BL Blue Narrow Hexes (typically run on front).
-Bodies Options
RC8T Bulldog Body (discontinued late 2016).
Print Wikipost
Old 04-18-2019, 02:30 PM
  #4576
Trader Rating: 28 (100%+)
So new truggy In 2020?
big lou is offline
Old 05-09-2019, 02:09 AM
  #4577
Default JCONCEPTS Finisher body
[QUOTE=ROSCOE;14392692]Ok guys, I was waiting on a few parts to show up to finish my little brothers truck up and decided to mock up the jconcepts finnisher body. Overall it's a nice choice for those looking for something else. I would say it's as good of a fit as any. I cut just below the cut lines for the stock chassis and side guards (m2c chassis need to leave them longer) and followed the cut lines for the rest except the engine is shifted slightly left and back and the snipped the rear to fit around the tower/body mounts. The key with the body is to shift it back to get the engine closer to the cab and cutting around the tower rather than leaving it long in the back and having a bunch of the nose sticking over the bumper. Here are a few pics.
Hi, saw this thread, lucky to get a ST-RR Evo2. You mention JCONCEPTS Finnisher body, for which brand was it????, ie Mugen, TLR???
Regards
gerry6112 is offline
Old 05-09-2019, 04:17 PM
  #4578
Team_Orange's Avatar
Trader Rating: 19 (100%+)
[QUOTE=gerry6112;15446423]
Regards
im pretty sure thats for the rc8t.
Team_Orange is offline
Old 05-09-2019, 04:38 PM
  #4579
Trader Rating: 126 (100%+)
Yeah I can’t recall. Could have been the mugen version as well. Sorry. Usually better about detail.
ROSCOE is offline
Old 05-14-2019, 08:42 AM
  #4580
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 85 (100%+)
Kyosho Inferno MP10 truggy ? Prototype images - Red RC - RC Car News
1/8 IC Fan is offline
Old 05-14-2019, 08:48 AM
  #4581
HaulinBass's Avatar
Trader Rating: 14 (100%+)
Every other truggy went wide rear pivot with a long arm interesting to see a shorter rear arm(mp9 rear uprights have quite a bit of offset) with a narrow pivot
HaulinBass is offline
Old 05-16-2019, 10:26 AM
  #4582
R/C Tech Elite Member
houston's Avatar
Trader Rating: 96 (100%+)
Looks like the whole point of design on this vehicle is to use as many buggy parts as possible and see if it will yield a well handling truggy
houston is offline
