Like Tree22Likes
Kyosho ST-RR
    Hide Wikipost
Old 10-19-2017, 10:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho ST-RR
Last edit by: tobamiester
Current running upgrades/Mods people are doing to this truck late 2016/early 2017.
-Chassis Options
m2c2850 KYOSHO STRR EVO WEIGHT FOWARD TRUGGY
-Engine Mount Option
IFW102 - Blue narrower Mount. Allows you to put Lock Nuts on top of screws that hold the Mount plates in.
Agama motor mount AGM6206
-For MP9 Knuckle conversion
Kyosho IF419 MP9 Knuckles
Kyosho IFW436 16degree Hub Carrier
Kyosho IF420 Knuckle Arm Collar (slightly thinner than STRR one)
Kyosho IF467 Long King Pin
-Strengthening upgrades
King Headz KP-360-BLK Front Torque Arm
King Headz KP-372RR-BLK Rear Torque Arm (extended chassis)
King Headz KP-300LB-BLK Lower Front Holder B
King Headz KP-300UL-BLK Front Upper Holder L
King Headz KP-329 Rear Brace Mount
IS157 Hardened Diff Case from Psycho Kruiser
IGW002GM Alum Rear Hubs
HB Outdrives #67197
-Replacing C-Clip Hinge Pins on Inner Susp Holder
HPI 109848 Hing Pins
Racers Edge/KFactory RCEK8034 Pins (Very hard to find)
or
Replace complete A/B/C/D Blocks with:
*M2C m2c2510 KYOSHO ST-RR/ EVO REAR TOE BLOCK
*M2C m2c2520 KYOSHO STRR EVO TRUGGY FRONT LOWER ANTIDIVER KIT
-Servo Saver Mod
IFW450 MP9 SS Alum Upper Arm
IF417 MP9 SS Lower Assembly
(See http://www.rctech.net/forum/showpost...postcount=4112 for full pics and description).
-Performance Updates
IFW327BL Blue Narrow Hexes (typically run on front).
-Bodies Options
RC8T Bulldog Body (discontinued late 2016).
Print Wikipost
Old 01-10-2019, 02:22 PM
  #4561
Trader Rating: 21 (100%+)
An optimus prime truggy. Awesome lol!
rcmoe is offline
Old 01-16-2019, 08:23 AM
  #4562
Default Evo 2
New with Kyosho ST-RR Evo2. When I wanted to order front lower suspension arm, I have noticed that there is not a left or right??? Little bit confusing. The other question. The suspension shafts with the e- clips, are there any other alternatives???
gerry6112 is offline
Old 01-16-2019, 08:54 AM
  #4563
maddog9's Avatar
Trader Rating: 30 (100%+)
Originally Posted by gerry6112 View Post
New with Kyosho ST-RR Evo2. When I wanted to order front lower suspension arm, I have noticed that there is not a left or right??? Little bit confusing. The other question. The suspension shafts with the cir clips, are there any other alternatives???
https://www.amainhobbies.com/racers-...rcek8034/p4055
We ran those when we use to run the truck about 10-11 years ago. You will have to see if you can buy them somewhere.
maddog9 is offline
Old 01-16-2019, 10:03 AM
  #4564
Trader Rating: 124 (100%+)
this is what you want. https://www.amainhobbies.com/hb-raci...204028/p633560
ROSCOE is offline
Old 01-16-2019, 10:47 PM
  #4565
Originally Posted by ROSCOE View Post
Thanks for the speedy reply
Old 01-17-2019, 05:12 AM
  #4566
Default ST-RR Body's
Any other brand body's that will fit the EVO 2???
Old 01-17-2019, 10:45 AM
  #4567
houston's Avatar
Trader Rating: 96 (100%+)
strr body is gorgeous in my opinion .....
couple of rtr bodies but the shape is cool ....
houston is offline
