Like Tree23Likes
Kyosho ST-RR
    Hide Wikipost
Old 10-19-2017, 10:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho ST-RR
Last edit by: tobamiester
Current running upgrades/Mods people are doing to this truck late 2016/early 2017.
-Chassis Options
m2c2850 KYOSHO STRR EVO WEIGHT FOWARD TRUGGY
-Engine Mount Option
IFW102 - Blue narrower Mount. Allows you to put Lock Nuts on top of screws that hold the Mount plates in.
Agama motor mount AGM6206
-For MP9 Knuckle conversion
Kyosho IF419 MP9 Knuckles
Kyosho IFW436 16degree Hub Carrier
Kyosho IF420 Knuckle Arm Collar (slightly thinner than STRR one)
Kyosho IF467 Long King Pin
-Strengthening upgrades
King Headz KP-360-BLK Front Torque Arm
King Headz KP-372RR-BLK Rear Torque Arm (extended chassis)
King Headz KP-300LB-BLK Lower Front Holder ‘B’
King Headz KP-300UL-BLK Front Upper Holder ‘L’
King Headz KP-329 Rear Brace Mount
IS157 Hardened Diff Case from Psycho Kruiser
IGW002GM Alum Rear Hubs
HB Outdrives #67197
-Replacing C-Clip Hinge Pins on Inner Susp Holder
HPI 109848 Hing Pins
Racers Edge/KFactory RCEK8034 Pins (Very hard to find)
or
Replace complete A/B/C/D Blocks with:
*M2C m2c2510 KYOSHO ST-RR/ EVO REAR TOE BLOCK
*M2C m2c2520 KYOSHO STRR EVO TRUGGY FRONT LOWER ANTIDIVER KIT
-Servo Saver Mod
IFW450 MP9 SS Alum Upper Arm
IF417 MP9 SS Lower Assembly
(See http://www.rctech.net/forum/showpost...postcount=4112 for full pics and description).
-Performance Updates
IFW327BL Blue Narrow Hexes (typically run on front).
-Bodies Options
RC8T Bulldog Body (discontinued late 2016).
Print Wikipost
Old 09-18-2007, 05:48 PM
  #31
Trader Rating: 34 (95%+)
Delta RC has them listed for $879.99......That might put a dent in the wallet..
ckt111 is offline
Old 09-22-2007, 01:05 AM
  #32
Michael P's Avatar
I just got to my house and my strr was sitting on the table waiting to be built. Shooting to get it built for next weekend for its first race.
Michael P is offline
Old 09-22-2007, 11:43 AM
  #33
Trader Rating: 29 (100%+)
hi micheal
when you finished build st-rr truggy and send pictire on post it okay
taztal3 is offline
Old 09-23-2007, 01:18 AM
  #34
Michael P's Avatar
Originally Posted by taztal3 View Post
hi micheal
I was planning on it
Old 09-23-2007, 12:05 PM
  #35
how was your rebuild your st-rr truggy ?
taztal3 is offline
Old 09-25-2007, 06:08 PM
  #36
Michael P's Avatar
I will be posting pictures Thursday night and if you have any questions about the truggy just ask
Old 09-26-2007, 04:27 PM
  #37
Default Set-up
My set-up for the ST-RR is available here-
http://www.kyoshoamerica.com/setupsheets/
Just look under the bullet point Inferno ST-RR
If you are not hard on the throttle I would recommend running a lighter diff fluid set-up. Possibly around 7k, 10k, 2k.
TRCRacer24 is offline
Old 09-26-2007, 06:26 PM
  #38
hi kcracer22
i have problem with setup sheet amd wont print it ?
taztal3 is offline
Old 09-26-2007, 06:37 PM
  #39
Michael P's Avatar
hi kcracer22
Hi try holding the ctrl key and hitting the p button and the print screen will come up.
Old 09-26-2007, 07:09 PM
  #40
hi micheal
did you run your new st-rr truggy last weekend ?
how was it ?
taztal3 is offline
Old 09-26-2007, 07:10 PM
  #41
i try that it but sheet was blank
taztal3 is offline
Old 09-26-2007, 07:20 PM
  #42
Michael P's Avatar
hi micheal
how was it ?
I was building it last weekend I am running it this weekend on Saturday I will let you know on Sunday morning
The only thing I can think of is print a blank one and write it all down
Old 09-26-2007, 07:29 PM
  #43
okay i will try it and but i look at set up sheet hard to see it small words .
why you make video of your truggy on track ?
taztal3 is offline
Old 09-26-2007, 07:58 PM
  #44
i look at ryan lutz setup sheet and he running a blue spring front and rear right ?
taztal3 is offline
Old 09-27-2007, 12:56 AM
  #45
Michael P's Avatar
i have no one to tape me sorry.
yeah i am just running stock for right now with 700 in the frount and 800 in the rear.
