Like Tree23Likes
Kyosho ST-RR
    Hide Wikipost
Old 10-19-2017, 10:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho ST-RR
Last edit by: tobamiester
Current running upgrades/Mods people are doing to this truck late 2016/early 2017.
-Chassis Options
m2c2850 KYOSHO STRR EVO WEIGHT FOWARD TRUGGY
-Engine Mount Option
IFW102 - Blue narrower Mount. Allows you to put Lock Nuts on top of screws that hold the Mount plates in.
Agama motor mount AGM6206
-For MP9 Knuckle conversion
Kyosho IF419 MP9 Knuckles
Kyosho IFW436 16degree Hub Carrier
Kyosho IF420 Knuckle Arm Collar (slightly thinner than STRR one)
Kyosho IF467 Long King Pin
-Strengthening upgrades
King Headz KP-360-BLK Front Torque Arm
King Headz KP-372RR-BLK Rear Torque Arm (extended chassis)
King Headz KP-300LB-BLK Lower Front Holder B
King Headz KP-300UL-BLK Front Upper Holder L
King Headz KP-329 Rear Brace Mount
IS157 Hardened Diff Case from Psycho Kruiser
IGW002GM Alum Rear Hubs
HB Outdrives #67197
-Replacing C-Clip Hinge Pins on Inner Susp Holder
HPI 109848 Hing Pins
Racers Edge/KFactory RCEK8034 Pins (Very hard to find)
or
Replace complete A/B/C/D Blocks with:
*M2C m2c2510 KYOSHO ST-RR/ EVO REAR TOE BLOCK
*M2C m2c2520 KYOSHO STRR EVO TRUGGY FRONT LOWER ANTIDIVER KIT
-Servo Saver Mod
IFW450 MP9 SS Alum Upper Arm
IF417 MP9 SS Lower Assembly
(See http://www.rctech.net/forum/showpost...postcount=4112 for full pics and description).
-Performance Updates
IFW327BL Blue Narrow Hexes (typically run on front).
-Bodies Options
RC8T Bulldog Body (discontinued late 2016).
Print Wikipost
Old 03-14-2008, 09:52 AM
  #151
Trader Rating: 33 (100%+)
i didnt have any bearings come with my knuckles.. i just used the stock size..
dgrobe2112 is offline
Old 03-14-2008, 09:56 AM
  #152
Tim Johnson's Avatar
use the stock bearings, and use the blue inserts
Tim Johnson is offline
Old 03-14-2008, 09:35 PM
  #153
vthondaboi's Avatar
I'm basically running Lutz setup but my turning radius is too wide/big. The car is very responsive but it doesn't turn the corners sometimes without hitting the guard on the other side.
What adjustments can me be for this? I have my toes pointing out a bit.
vthondaboi is offline
Old 03-14-2008, 11:03 PM
  #154
rcracerjunky's Avatar
Trader Rating: 1 (60%+)
Default str
I bought the truggy used sorry if i miss lead you. Thanks for the info.
rcracerjunky is offline
Old 03-14-2008, 11:04 PM
  #155
Default str
Thanks i will order some up asap.
Old 03-15-2008, 12:15 AM
  #156
Trader Rating: 49 (100%+)
vthondaboi, check the trim on your radio and make sure it isnt turned down.
weaponx is offline
Old 03-17-2008, 08:51 PM
  #157
Powerlink's Avatar
Default steering tie rod ends.....?
Has anybody tried the standard steering tie rod ends on there st-rr off the 777 wc? I am running proline LPR rims and tires ,so the rims will not hit or scrub at full lock .Or is there some other reason to run the st-rr steering tie rod ends.
Powerlink is offline
Old 03-25-2008, 02:42 PM
  #158
vthondaboi's Avatar
can anyone suggest an edit to Lutz's or King's from kyosho's web site here:
http://kyoshoamerica.com/cars/index....=manualssetups
I race on smaller technical tracks that are pretty rough and traction is low, running Werks Lugs tires.
I switched from running all blue spring to blues in front and stock greens in rear. That helped a bit along with switching from 1.1 to 1.0 springs.
Currently diffs are setup 7/14/3. Shocks are one in on the bottom from the outside position for front and rear. They're one in from the outer on the upper mount for the top shock positions.
Running 700 oils in the front shocks and 650 rear.
There's a double that's not too long but a bit tall for a regular jump that immediately turns into a single. But I have trouble landing it sometimes as it like to go onto it'd lid, seems unstable landing. I have no trouble making the bigger jumps or longer ones, just this one.
Tracks not too big so any other changes to make turning easier would be a great help.
Old 03-25-2008, 08:41 PM
  #159
Powerlink's Avatar
vthondaboi, Are you still running the rear blue springs on the front ? Get the 1.6 8 turn blues .Lighter fluids on a track with less traction works good for me,also will turn better on the ruff areas .700 or 800 kyosho oil in the rear shocks with blues springs.Tire selection is very important .Im using the lpr holeshots and crimefighters depending on the conditions .these made a big difference in turning ,and acceleration for me.
Old 03-26-2008, 02:57 AM
  #160
vthondaboi's Avatar
yea I did switch the front springs out to the proper ones finally
Old 03-28-2008, 09:22 PM
  #161
pitpop's Avatar
Default Stickers!!!!
OK, all you Red Army faithful, here are all the stickers you want! They are very high quality vinyl.
http://www.redarmygear.com/
I think the site takes paypal...
pitpop is offline
Old 05-05-2008, 03:10 PM
  #162
CRASH's Avatar
Trader Rating: 26 (100%+)
Just got a STRR and am looking for advice on what is the best motor and pipe combo available for it.
I am looking at the GRP .28 Tuned motor and the EFRA 2053 pipe but I am open to all suggestions.
Thanks,
CRASH is offline
Old 05-05-2008, 03:34 PM
  #163
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Post
If your smooth on the trigger, I would take a look at the O.S XZ .28 with an O.S 2050 or 2060. Great power combination, but some like me, need a very smooth finger to handle the unbelievable power.
Brad
Brad S. is offline
Old 05-05-2008, 06:35 PM
  #164
Strrategic is offline
Old 05-06-2008, 01:15 PM
  #165
SIRIO .21CL7B and a Sirio 2057 pipe.
