O.S. .21 RG Question >
Old 07-02-2007, 12:35 AM
Trader Rating: 14 (100%+)
Default O.S. .21 RG Question
I have an O.S. .21 RG that I've kept around for a back up engine that I'm about to break in. Does anyone know how many shims and what total thickness should be used to run 30%? It has 1 shim in it now. I'm not sure how thick it is I haven't measured it yet. Also does anyone know what other brand / type engine shims will work in a RG?
sdmlsu1 is offline
Old 07-02-2007, 02:57 AM
freefallmarine's Avatar
My RG's run fine with just that 1 shim. Im running 30% Odonnell in them with over 5 gallon's on one and 2 gallon's on another.
freefallmarine is offline
Old 07-02-2007, 06:33 AM
Davidka's Avatar
Trader Rating: 86 (100%+)
Run it like it is out of the box. Break it in on the #8 plug that comes with it but change to an A5 after if you're running 30% and it will run much cleaner on the top end (no detonation).
Davidka is offline
Old 07-02-2007, 09:49 AM
Thanks for the help guys.
sdmlsu1 is offline
