RC10GT2 thread!
#16
I GOT MY GT2 ON THE TRACK LAST WEEK AND THE THING IS A BEAST .I AM RUNNING A TZ AND GETTING TONS OF WHEEL SPIN IS ANYONE ESLE USING A TZ I ALSO HAD THE SAME SCREW PROBLEM DOSE ANYONE KNOW ABOUT A RESTRICTER FOR THE TZ
#17
The TZ is alot of motor...Try to find a CV-R it is so much easier to drive. I dont know if they make a restrictor for the TZ. Alot of the other AE guys made an adapter for the 10E carb on the TZ to tame it down a little.
#18
#19
INDEX FINGER WORKS WELL BUT THIS MOTOR IS ALOT FOR A 1/10 TRUCK I AM SURE THAT THERE ARE PEOPLE OUT THERE THAT CAN CONTROL IT BUT WHY TRY TO CONTROL SO MUCH POWER 3/4 THROTTLE DOWN THE BAC STRAIGHT AND I PUNCH THE OTHER 1/4 AND THE THING SPINS OUT OF CONTROL I HAVE A CVR ON THE WAY WILL USE THE TZ FOR ON ROAD CAR
#20
You can limit the throttle epa which is basically the same thing as putting a restricter in the carb. Just run it down the straight and keep setting it lower until it's not stupidly fast or out of control and that should make it better everywhere else as well. I do this on my brushless T4 and it works well. On my gas trucks I usually just tune them a little fat to tame them down depending on the track surface and layout. You can change the gearing to tame it down as well. Lots of different ways besides buying a new engine. But since you have one on the way that's the easiest : ) CV-R is a great engine.
#21
EPA IS SET TO OPEN FULL THROLLTE I WILL LOWER IT AND GIVE IT A TRY .I HAVE MY THROTTLE SPEED AT ABOUT 45 TO SLOW IT DOWN .I THINK I WILL LIKE THE CVR IN MY GT2 BETTER AND THE TZ IN MY ONROAD
#22
TZ is nuts on power you may have a real hard time tamming that beast. Alot of top drivers are putting the 12e carb on them. Are you adding the weight to the front end like everyone else. I run a Pixy 12 and it too is sick on power at times it tough to keep the front end down add 1 ounce of weight to the front end.
#23
i just installed a new carburator 10e is seen a couple factory drivers using it on the tz thought i give it a try
#24
I don't see where you need anything more than a TG (roughly the same as a cvr, but with a rear exhaust) Using bowties on a really sandy track it was really stable. I am going to try panther step pins next and see if i can get more bite
#25
Hey guys, Have any of you guys run 30% nitro on the OS TG
Is it safe to break the engine in????
I run 30% on my 1/8 buggy and I don't want to be buying diferent fuel
#26
Check the squish in the head. Everybody told me .025" to .030" and you'll be all set for 30%. To check it you bend a piece of solder 90* so it'll fit down the glow plug hole. Make the bend face the same direction as the crankshaft so the piston can't flop, then rotate the flywheel over so it squishes the solder. Pull it out and measure it. If it's less than the above measurements add head shims till it's there.
#27
I'm running 20% in mine with the gearing that associated provided and it runs awsome
#28
I have a TZ in my GT2 and what I did to tame it was turn down the ARC on my M11 and my Expotential till it was a little smoother on the throttle.
#29
anyone know what kinda muffler jared tebo runs on his gt2??
#30
The Factory Team Smoothy pipe. Its new, and just as the name suggests its smooth
