Jammin CRT .5 = 1/12 Truggy
#46
I wanted one of these .5 Minis when I saw it in the mags, but when I saw the price of there website, I said maybe one day. Instead I got the X-Ray Nitro 1/18. Its fast, and fun, dont get me wrong. But when I saw the price on the website I got the X-ray, I was mad. On the other hand, I got the electronics package with the started box and that took it a little higher. Now I am tring to sell the X-Ray so I can get the Jammin Mini. I can't wait
#49
That vid is sweeeeeeet..
Exactly like that...OK I can not wheel it like Jay but you can gun down the big guys without a problem....I can not wait till I am in better health and more of these at the track.....the next big class....just like truggy has gotten...Jay is such a tread setter....Next thing you know he will create a new electric version, can you say Brushless/lipo CRT.5......DANG IT NOW I GAVE HIM A GREAT IDEA>>>>>SHEEESH...
-Shookie <><
-Shookie <><
#50
electric crt.5
i saw this on radio control zone here is the post.
IBJAMMIN
Member Join Date: 02-18-2006
ECRT.5 I'm working on a brushless lipo set up I was going to try it out with a gas motor but decided to go for it and convert it and see how it does should smoke about any gas set up with a 3s 4000 11.1v pack and a MM 5700 motor.
IBJAMMIN
#54
UPDATE!
Jammin 1/12th CRT .5 screw kits are now in stock!
Jammin 1/12th CRT .5 210-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers, and set screws.
Please note the kit does not include the 2.6mm x 10mm flat head diff screws. The stock screws are a course thread self tapping type screw. I have a 2.5mm x 10mm flat head machine screw but not sure if they'll work. The Diffs are pre-assembled. If the cups were new, they would most likely work. But I'd need to test them in a pre-built diff to see if you can replace the self-tapping screw with a machine thread 0.1mm smaller in diameter.
Thanks and best regards,
#57
Looks like the 94761 servo from Airtronics would be a good one for this truck. I have one comming from GP. So im gonna have to get on the ball and get some gear for this little monster.
Cole
Cole
#58
For some reason I cant get the clutch bell spaced right. It seems the collet is to big and will not let flywheel have a normal gap to the front engine bearing.
After get everything shimmed right the front clutch bearing sits 1mm ahead of the end of the crank. Need a new collet or a Losi 8ight shim.
Im using a OS TZ .12 3 port.
#59
I had troubles with my picco red dot engine so i put my os .12 tr in, one word, WOW! This thing is impressive
