Jammin CRT .5 = 1/12 Truggy
#2296
Sad day, body was recently painted and still in great shape.
#2297
Hey do any of you guys have a BCE pro chassis kit and im having issues setting mine up and I could use some parts aswel I got stuff to trade.
#2298
I don't know how many readers have had the chance to see this truck on the track, but you're going to be crazy.
#2299
#2300
I want any parts I can get or whole trucks
#2301
hey guys picked one up this week having a hard time getting it started any one got the carburetor settings for it? IT seems like i cant find it
#2302
#2303
#2304
#2305
Mine is for sale, if anyone is interested. It's in the for sale section.
#2306
Burned through a quart with the crt .5 today. Car ran great, no break downs. But I notice the tune leans out when the tank gets low. Would adding more fuel line help with that all?
#2307
Shorten the line from pipe to tank and youd get more pressure in there, might help.
#2308
if it’s the jammin picco red dot these are the settings based on info from another thread.
The factory settings of the engine are as following and are a good starting point for you. Turn in the needles completely (Caution: Do not
over tighten them!) and loosen them the required number of turns:
Idle screw: Should be open 0.5-1.0mm.
Low speed needle: Should be open: 6,75 turns
High speed needle:Should be open 5,00 turns
CARBURATING PICCO ENGINES
Engine works better on the rich side (HSN) and normally needs more than a couple of laps to reach the operational temp. Start on the rich side (HSN) and after 4 or 5 laps tune the engine. Doing this process on the bench (or starter box) normally overheats the engine driving you to a wrong tuning and maybe causing a damage. Set the engine a little bit rich (if you progressively open the carb, the engine responds quick but at 3/4 rpm becomes rich (not really 4 stroking but rich) Then at the track after several laps (at least 5) if the engine is still rich lean it.
Regarding LSN, Run the LSN a little bit on the rich side and still keeping the engine with a good idle (Very low rpm idle, is better for fuel consumption and handling of the car after off throttle).
After pre-heating the engine, just pinch the fuel line and if the rpm remains the same for 4 to 5 seconds and then the engine revs up and shuts off, that’s the best setting for a large track with long straight away. If the track is really short, and full of hairpins, LSN needs to be more lean, because the engine never revs up for a lot of time, and so if you keep the same setup described before it is always rich out of the corner.
#2310
I know we who have these CRT love them so i thought I would share mine. I purchased the kit new and have had it ever since.
I still run it on occasion. Was ripping the little jewel last week. They are great trucks!!
