Losi 8ight building and setup
#1336
The servo that your freind setup that got 43 minutes of track time. Is that the longest you've gone so far with one servo?
#1337
Ficsher is one of Losi's top electric drivers... awesome with an 8ight as well.
#1338
Originally Posted by FlyByWire
Id say the longest amount of run time... The others lasted about 3 race "days"
#1339
has anybody ran two of the khz 6061 shoes along with two of the 7075's? what springs? how did it work?
#1341
Originally Posted by infanterene
Although I have bought another buggy and am extremely happy with it. I am keeping my 8 and whatching this thread carefully. Flybywire I really hope your problems are over.
If this servo thing gets solved for most people i will try it again.
I hope (and believe) my servo problems are over. Another Losi factory driver that helps me with setups, hasnt had a problem yet either. This car may be just too sensitive to even the slightest error in servo setup.
#1342
#1343
I bought a CEN Martrix Pro long chassis. It has an OPS motor that easily pulled on my friends P5.I bought it used from a very experienced racer who had it set up very well and he fine tuned it for my driving style. I easily shaved 5-7 seconds of my average at the local track. Next week I am buying one of his short chassis to try it out.
this car is very easy to drive fast, the harder I push it the better it runs.
#1344
I am running 4 KHZ 6061 shoes with silver and green springs and the clutch feels great. Very smooth engagement with minimum wear. Still no problems with the throttle servo at 1 1/2 gallons. I find the more you relax and drive smooth the faster you are with this car. This car reminds me of my Xfactory X-5 in alot of ways.
#1345
Fischer thinks (and so do I, now) that it was the throttle endpoint. I wasnt looking down the venturi when setting the hi-point, rather watching the throttle arm. I'd go until the arm stopped, then back off a click or two. Well, as we all know, on most slide carbs, the arm will pull out past the venturi opening.... Sitting on the bench its not a problem... but at WOT with the chassis flexing, it will be.
Live and learn. He set this one up himself, and its out of his own pit box.. and doesnt want it back until we know for sure that's what the problem was.
#1346
i removed the entire throttle return spring and cut the cup down.
i use a carb return like the rc pro series requires. a simple rubber band wrapped around the carb. this lets my servo sit with 0 "noise" while sitting at netural. the "noise" at neutral is what results in burnt servos as they are strained constantly not just at WOT. this fixed my servo problem. also the kingheadz servo tray stiffner will take all the movement out of the throttle servo. i am using coreless digital JR 9000S.
and i am running the kingheadz 7075 all 4 4 golds. my track is crcrc so that is the reason for 4 gold. mad traction no loose stuff.
kyle
kyle
#1347
Im about to start building my 8ight and im aware of the shock shaft and piston mistake that is being made. I have been told to spray acetone on the screw and in the threads of the shaft because it has some protected coat on the threads to prevent from rusting,,,,etc. Then hit it with some loctite correct? Just curious if anyone has heard about this scenario, thanks
#1348
However, I screwed the screw into the piston first, then I put loctite on the exposed threads.
#1350
And in addition to that slightly inlarge piston hole and Put the lock tight in the shaft itself, let sit all day before you put them together. I went a step further and scribed a line in the threads of the screw with a x-acto knife, I know some will say this sounds crazy but I havent had any issues with my shocks and ive changed pistons with out any issues. dont go crazy with it just enough to give the threads a little better bite.
