RC10GT - Hinge Pins >
RC10GT - Hinge Pins
Like Tree2Likes
  • 2 Post By HaulinBass
RC10GT - Hinge Pins
Old 06-30-2022, 05:21 PM
ceh329's Avatar
Default RC10GT - Hinge Pins
Hello, I just got a RC10GT and I'm going through it and Im wanting to restore it enough to run at the track. Anyone know of any after market hinge pins that can be used with the truck? I would love it if I could get rid of the e-clips
ceh329 is offline
Old 07-08-2022, 03:22 PM
petersen114's Avatar
none out there that I know of.
petersen114 is offline
Old 07-08-2022, 05:20 PM
1995 Monster T's Avatar
Circle clips are better than e clips.
1995 Monster T is offline
Old 07-08-2022, 05:26 PM
Bud
I always had problems with the e clips falling off and having the pin slide part way out on my RC10GTs. What I finally ended up doing is tapping a 4-40 hole in the mount where the hinge pin goes through and flatting a small spot on the pin so the grub screw hits the flat spot on the pin. I still lose e clips but the pin stays in. This is on the inner pin. I didn't do the outer ones. I always seemed to lose only the inner ones.
Bud is offline
Old 07-12-2022, 02:32 PM
HaulinBass's Avatar
Trader Rating: 15 (100%+)
use a drop of shoe goo once the eclip is on
Bud and st_dragn_wagen like this.
HaulinBass is offline
Old 07-19-2022, 02:37 AM
Just chuck the stock pins up and cut a thread on them with a die set. Add locknuts a la losi.
Licklobster is offline
Old 07-19-2022, 01:15 PM
Only downside is they are soft steel and will bend on impact.
Old 07-19-2022, 04:08 PM
Bud
I don't think they're long enough to put a locknut on the ends. At least mine aren't.
Bud is offline
Old 07-19-2022, 10:26 PM
measure the diameter, order pins in the length you need, cut threads. It's only as hard as you make it.
Old 07-20-2022, 12:59 AM
Bud
why would I do that? I've got titanium pins with a set screw plus e clips. If I was going to do anything more I'd put a drop of shoe goo on the e clips like HaulinBass suggested.
Bud is offline
Old 07-20-2022, 08:51 AM
You can't cut harden steel with off the shelf threading dies. Only mild steel. If you don't like e-clips get the full circle clips.
