Tekno NT48 2.0 Nitro Truggy >
Like Tree17Likes
Old 04-10-2022, 07:15 PM
  #16
The clutch that comes in the kit isn't the best by any means.
petersen114 likes this.
jdsand5 is offline
Old 04-10-2022, 08:59 PM
  #17
Waiting to put my reds clutch in once stock one takes a 💩
ls1jimmy is offline
Old 04-10-2022, 11:52 PM
  #18
The Reds or the TLR clutch is a better setup IMO. The tekno clutch needed ALOT of shims to get it correct. The truggy is very impressive minus the clutch.
jdsand5 is offline
Old 04-12-2022, 02:58 PM
  #19
Default Jconcepts Finnisher nt48.3 body on nt48 2.0
Anyone know if the finnisher body nt48.3 will work on the nt48 2.0
Critchy87 is offline
Old 04-16-2022, 04:36 PM
  #20
petersen114's Avatar
Shocks suck bad for this kit. At least mine did.
petersen114 is offline
Old 04-16-2022, 06:29 PM
  #21
whats the issue with your shocks ???
ls1jimmy is offline
Old 08-24-2022, 10:50 PM
  #22
I was told that you can use a different motor mount to push engine forward to accommodate a standard clutch bell. Anybody using this method? What mount are you using ?
ls1jimmy is offline
Old 08-25-2022, 06:28 AM
  #23
Originally Posted by ls1jimmy;[url=tel:15933569
15933569]I was told that you can use a different motor mount to push engine forward to accommodate a standard clutch bell. Anybody using this method? What mount are you using ?
I heard the same as well but couldn’t find anything. I just designed and 3D printed a simple fixture to re-drill the engine mounting holes about 2.8mm forward after slugging the original holes. Protek clutch fits perfect.
Old 08-25-2022, 10:08 AM
  #24
Ok that’s a good way of doing it. Thanks for the quick response.
ls1jimmy is offline
Old 08-25-2022, 11:21 PM
  #25
Would the Buku fit without modification?
Cardiak is offline
Old 08-26-2022, 07:05 AM
  #26
tobamiester's Avatar
Trader Rating: 354 (100%+)
It should, providing its the 34mm flywheel, shimmed correctly, and providing you run the Tekno clutch bell.
tobamiester is offline
Old 08-28-2022, 01:05 PM
  #27
Anyone else having trouble with the hub axle pins snapping in half?
jdsand5 is offline
Old 08-28-2022, 03:34 PM
  #28
Nope…this truggy seems indestructible to me so far. I only race it…no bashing
ls1jimmy is offline
Old 08-28-2022, 04:53 PM
  #29
what’s the issue
Logante is offline
Old 08-28-2022, 05:52 PM
  #30
Originally Posted by Logante View Post
what’s the issue
they leaked bad. I got the issue somewhat solved at least for now. The problem was that the shafts in my kit were not smooth and we’re quite pitted and rough. I did get replacement shafts after contacting Tekno and then sending pics but they weren’t much better. Still leaking but better and usable.
