Kyosho 2020/21 MP10 TKI2
#31
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
agree with payton 34.. the green, purple and blue body looks very nice..
#33
It would be a bad look, no doubt. Lol
#34
Any feedback on the high shock tower is appreciated...
#35
Super Moderator
better in the rough blown out tracks.. i like the new tall tower as the inner camber link is different.. i like the different adjustment setting
#36
Just ordered my new MP10 tki2 can't wait for it to arrive.
#37
what weight shock oil is everyone running Front and Rear.....?
#38
Super Moderator
thats a loaded question.. with the current weather conditions all over the country you can have a bunch of different answers..
but summer i start with
550f 1.3x5
450r 1.4x5
winter indoors
600f 1.2x8
500r 1.3x8
550f 1.3x5
450r 1.4x5
winter indoors
600f 1.2x8
500r 1.3x8
#39
yea I'm in so cal so its basically warm year round out here....thanks for your input
#41
Super Moderator
i agree but they are selling so you will start to see more.. good things take time.
#42
Anyone having issues with how tightly the TKI2 body fits? My throttle linkage rubs pretty bad with a Kyosho aluminum horn. End point is set to the carb restrictor and the rod is screwed all the way into the plastic part that connects to the carb with no threads showing. Seems to be the barrel on the outside of the horn that’s rubbing. It moves the body, but doesn’t affect anything. Also, the front left corner where the fuel tank is bulges out about a half inch when I push the body down to put the clips in the mounts. I’ve slotted the front and rear holes thinking the body was bound up with no luck. Disappointed knowing my race body will be here in a couple of weeks.
#43
#44
Just got my mp10 tki2 today and am currently assembling it. The gearboxes don’t seem to rotate as smooth as I would think and there is a certain point where it gets a tiny bit rough to turn. I tried with no shims and with 1 shim and it didn’t make a difference. Not sure if this is normal on this car... Do the gears need to be broken in? Will it smooth up once I run a tank or Two through the drivetrain?
#45
Super Moderator
