Are these easily broken? Kyosho IF488 >
Like Tree1Likes
  • 1 Post By biggreen
Old 07-02-2020, 04:03 PM
Questions?? Are these easily broken? Kyosho IF488
The Kyosho ready set tki3 came with cast aluminum steering arms... bought kit used (and broken) from eBay, ordered another set, broke one again in less than a tank of fuel... I'm a 8th scale noob to say the least, I thought my trx4 crawler was fast in it's 2nd speed until I got this...
So I bit the bullet and bought the machined aluminum units for almost 100$ Should I start saving up for another set or should these last?
biggreen is offline
Old 07-02-2020, 04:32 PM
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 62 (100%+)
the 488 hubs will last a long time.. the cast aluminum ones are soft.. you will be fine for a long while unless you hit something full speed.. curb. tree. fence..
J.Whiting is offline
Old 07-03-2020, 11:39 PM
Right on thanks.
on another note.. has anybody had luck with the 26 dollar eBay set? ebay.com/itm/400508264974
they say they are 6060 aluminum...
biggreen is offline
Old 07-04-2020, 01:43 PM
Trader Rating: 25 (100%+)
Originally Posted by biggreen View Post
Right on thanks.
those are pretty good they look tough. Don't put to much aluminum in your car, spindle and spindle carriers and rear hubs and a steering column top plate is usually as far as u want to go. Don't get aluminum arms or diff cases as your car won't handle and minor crashes will start bending the stuff around it very easy. The plastic parts are engineered to help the car flex upon hard impacts and usually not break. In the past a few cars had issues with broken arms (older mugen and Kyosho buggies) the fix for racers was either another brands plastic arms or carbon arm stiffeners (the ones that covered the entire arm before they started integrating them into the arm which u could probably buy and fit on your kyosho as I believe the mp10 arms fit the older mp9 model.
Matt Piva is offline
Old 07-04-2020, 01:51 PM
Ok thanks, yeah I don't need an aluminum bling machine, just something that is strong and reliable and flexible in the right places.
biggreen is offline
Old 07-09-2020, 09:54 AM
Attempted to clear some triples and failed miserably, but the IF488 set stayed intact. Glad I bought those.
J.Whiting likes this.
biggreen is offline
