hot bodies owner
Old 10-06-2019, 02:03 AM
Default hot bodies owner
does any one have any trouble with spur gear issue few times the spur get worn without any reason the mesh is ok
maybe need to have havy duty spur ?
what about the stifner on the main diff in the chassie ?
another thing is the battery is very tight in box ? do you have this also or using other battery
dimax78 is offline
Old 10-06-2019, 08:25 AM
I had a problem once where the plastic center diff mount had wear in it which allowed the diff to move around. Replaced the center diff holder and it was cured. Also are you using the V2 plate that sits under the center diff housing to stop chassis flex in that area. The battery is a little tight but not an issue.
wreckingball is offline
Old 10-07-2019, 03:48 PM
what plate are you running under the center diff
d817 came with plastic.
D817v2 comes with metal and you can use 2 screws to stiffen it up with the 2 screws in.
What battery are you using
protek 2000mah lipo fits good
dynamite 2000mah fits good
I just got a reedy 2700mah pack and it also fit in fine.
jersey is offline
