Like Tree128Likes
Tekno NB48 2.0
    Hide Wikipost
Old 09-10-2019, 04:53 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno NB48 2.0
Last edit by: tobamiester
Old 09-27-2019, 11:09 AM
  #76
Big Will's Avatar
Originally Posted by ravage View Post
Does any one know what mip bypass pistons will work?
The Tekno ones
Big Will is offline
Old 09-27-2019, 12:58 PM
  #77
dbizzle5's Avatar
I have just put the Tekno ones in. They are 6 hole which need drilling obviously to what you’d normally run but as the kit ones are 5 hole it was a bit of guess work really. I’ve started with 6 x 1.4. Feels good with 500cst oil front and rear. Yet to be tested but this seems a good starting point to me.
dbizzle5 is offline
Old 09-27-2019, 09:19 PM
  #78
Shady3275's Avatar
Has anyone had a chance to get some good track time in yet with the new kit ? I’m still building my mine, hope to be finished with it in a few days
Shady3275 is offline
Old 09-28-2019, 05:37 PM
  #79
Folks, can someone explain the physics behind the active toe. I haven’t finished the kit yet but how do the inserts allow the toe to change as the suspensions moves ?
thx
jehjr68 is offline
Old 09-29-2019, 05:57 AM
  #80
Shady3275's Avatar
This is the first kit I’ve ever built that has emulsion style shocks. How often will I need to top off with oil and re-bleed them ? I’m guessing maybe at the start of each day at the track.
So if I build my shocks today will I need to bleed them if it’s three weeks before I take my car out to the track ?
Old 09-29-2019, 07:14 AM
  #81
Red face
Originally Posted by Matthew_Armeni View Post
Also pick up some TKR5125 o-rings to use as uptravel limiters. They're good to have for tuning as changing your uptravel can make a surprising difference on the track.
Silly question-where would you be putting these o-rings-on the piston shaft outside the shock body to restrict the amount of compression travel or inside the body above the piston?
nitrorig is offline
Old 09-29-2019, 07:55 AM
  #82
speedy2's Avatar
on the shaft ... between shockbody and shaft clevis
nitrorig likes this.
speedy2 is offline
Old 09-29-2019, 10:37 PM
  #83
Default Throttle servo horn?
Which throttle servo horn do I use with a protek servo? I stripped all three of them out 🤦🏻*♂️
Cmt600 is offline
Old 09-30-2019, 05:01 AM
  #84
kiwi_tim's Avatar
Trader Rating: 17 (100%+)
The EB410 ones I bleed ever run, forgot to do this on it's maiden day, but testing again tomorrow night, so will see if it's worth while.
Put about 1.5L through it, and it seems great, hit a peg at full speed and throttle and no damages, easy to drive coming from a Tki4.
Have bumped oils up to 725/650 so see how that goes, was quite easy to drive and consistent over long runs, a little on power push, but for the seemingly average driver like me that probably not a bad thing
kiwi_tim is offline
Old 09-30-2019, 05:57 AM
  #85
TAW
Trader Rating: 18 (100%+)
Protek is 25T same as futaba. Make sure you are setting your endoints correctly.
TAW is offline
Old 10-01-2019, 09:35 AM
  #86
MaricopaAgent's Avatar
Trader Rating: 28 (100%+)
Any insight to the hard arms being longer? Great idea for a different material, being longer has me scratching my head tho.
How about some aluminum sway bar centering caps?
MaricopaAgent is offline
Old 10-01-2019, 10:13 AM
  #87
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
The harder material shrinks less in the mold.
0verkill likes this.
Matthew_Armeni is offline
Old 10-01-2019, 11:50 AM
  #88
TAW
Shrinkage was my first guess.
Alum sway bar collets would be awesome, I am already starting to see the ones one the front get pushed around cause I'm afraid to crank down on the plastic ones.
TAW is offline
Old 10-01-2019, 03:32 PM
  #89
I thought about making some of theses out of aluminum, i may try it this weekend.
sp88 is offline
Old 10-04-2019, 12:08 AM
  #90
Matt, can you hazard a guess as to how long it will take for some or most of these features to make their way to the electric side of the house?
smirkracing is offline
