Like Tree128Likes
Tekno NB48 2.0
    Hide Wikipost
Old 09-10-2019, 04:53 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno NB48 2.0
Last edit by: tobamiester
Old 11-18-2019, 09:40 PM
  #211
Propchecku37's Avatar
Trader Rating: 74 (100%+)
STEERING POST SPRING
I’ve noticed on some set up sheets, depending on the driver they have different tension on the steering post spring. For Example What’s the reason for having the spring tension 1/2 turn out from tight compared to 1 1/2 turn out? Is it really that noticeable? Does a rough bumpy track need more or less tension than a smoother track?
Propchecku37 is offline
Old 11-19-2019, 03:07 PM
  #212
It's actually very noticeable if it's too loose as it will cause steering response issues. Often when it's too loose, it will be difficult to make tight corners and the car can "wander" on rough tracks. Most drivers will run it half a turn from fully tight.
MattDub is offline
Old 11-20-2019, 08:24 AM
  #213
fiveoboy01's Avatar
Trader Rating: 30 (100%+)
I crank mine down pretty much all the way, always have on my buggies. Never have had an issue but I always use a good strong servo on the steering.
Bigv likes this.
fiveoboy01 is offline
Old 11-21-2019, 07:53 PM
  #214
Shady3275's Avatar
Is anyone else using velcro on their stock body. It looks like there is two notches for it on both sides of the radio tray/ mud guards that align with the body ?
seems like last time I tried this on my nitro buggy the Velcro and adhesive started to melt from the heat coming off my pipe and header
Shady3275 is offline
Old 11-21-2019, 09:44 PM
  #215
fiveoboy01's Avatar
I don't use them. I don't even think velcro came with the kit? If it did, I missed it.
The adhesive doesn't hold and you usually just end up pulling both pieces off with the body.
Got it on my EB410 as well, same thing. Mostly useless.
Old 11-22-2019, 06:09 AM
  #216
tobamiester's Avatar
Trader Rating: 360 (100%+)
I use them. Didn't have any melting, But I think the oil/possible heat will cause the left side tape to detach from the chassis and you have to clean and replace.
tobamiester is offline
Old 11-22-2019, 08:14 AM
  #217
I use just the fuzzy side on the chassis guards. Keeps the body from rubbing too much...
blankenj99 is offline
Old 12-01-2019, 12:42 PM
  #218
Originally Posted by speedy2
Tekno comming out with there own servos? or a sticker on them? throttle looks like their own
TrespasseR_MN is offline
Old 12-01-2019, 01:25 PM
  #219
mebolson's Avatar
Trader Rating: 41 (100%+)
Those are Highest servos with Tekno put on them.
E
mebolson is offline
Old 12-08-2019, 04:11 PM
  #220
Has anyone tried the universals instead of cvd’s on there set ups? What was the change in handling?
Old 12-25-2019, 08:30 PM
  #221
Default Trouble with shock o rings
Iím having issues with Bag L with the o ring that fits into the shock collar. Did anyone else run into any issues? It just seems like the o ring is not fitting snugly enough into the collar for me to twist it up the shock body. Iíve never had an issue like this during a build. Any help would be greatly appreciated.
artis1 is offline
Old 12-25-2019, 10:08 PM
  #222
fiveoboy01's Avatar
I didnít have any issues with the fit.
Make sure you are not accidentally swapping the collar o-rings and the shock cap o-rings. The latter are significantly thicker.
artis1 likes this.
Old 01-09-2020, 12:56 AM
  #223
lexusbest's Avatar
Is there a possibility to move rear shocks to the front of the arms?
lexusbest is offline
Old 01-27-2020, 08:19 AM
  #224
Can anyone here give a comparison of the nb48 2.0 to the Losi 8X?
shark2288 is offline
Old 01-28-2020, 09:47 AM
  #225
IMO the NB48 being a Corvette and the 8X being a Camaro. Iíve had different buggies over the years nitro and Ebuggy and Tekno has exceeded my expectations.
artis1, MaricopaAgent and Bigv like this.
