Like Tree128Likes
Tekno NB48 2.0
    Hide Wikipost
Old 09-10-2019, 04:53 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno NB48 2.0
Last edit by: tobamiester
Old 11-02-2019, 11:42 PM
  #181
Propchecku37's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Shady3275
Is anyone else using a Lipo on/off switch on their buggy?
If so where are you mounting it with this new electronic/radio tray design and running your wires? Iím using the Protek RC lipo switch, trying to decide where I need to mount it.
If you have pics to share that would be great
Iíve seen a couple of other guys already posted about this and I mounted mine the same way with no problems.
Propchecku37 is offline
Old 11-03-2019, 12:20 AM
  #182
fiveoboy01's Avatar
Trader Rating: 30 (100%+)
I have the same switch and it is mounted in the same spot.
Only thing to watch for is be sure the wires arenít pinched or being pulled on.
Shoe Goo or RTV works well for mounting it securely but enables you to remove it fairly easily if needed.
fiveoboy01 is offline
Old 11-03-2019, 08:32 AM
  #183
R/C Tech Elite Member
Spads11's Avatar
Trader Rating: 33 (100%+)
Is anyone also having trouble with the emulsion seals? Mine did not fit into the cap very well. I'm going to try some leftover Kyosho emulsion seals to see if they fit and work better.
Spads11 is offline
Old 11-03-2019, 08:37 AM
  #184
Spads11's Avatar
Otherwise, build went flawlessly. No missing parts and clear manual. Car has some great design features on it to prevent common failures in c hubs. I really like the engenuity built into this car. My first run with the car, few practice laps, went well before my emulsion seals gave way and oil leaked out of the vent hole. Car has a ton of turn in the my Xray did not have - that took a couple of laps to get used to not turning into pipes. Car jumps nicely and flat with little to no inputs. I ran the stock setup as I wanted a base to start from. More practice laps to come today and this week. So far, I'm impressed with the way the car handles with the stock setup.
artis1 likes this.
Spads11 is offline
Old 11-03-2019, 08:49 AM
  #185
tobamiester's Avatar
Trader Rating: 360 (100%+)
There is a knack to installing the seals. When you install em, they're bigger than the groove they sit in. What I do is grease them a little, then you kind of push down opposite sides, into the groove, and then you'll have adjacent parts of the oring sticking up. Then basically tighten down on the shock body and it will be pushed into place. Once you've bled the shock; put in the bleed screw and pump the shock 20-30 times. if its not seated properly you'll know.
tobamiester is offline
Old 11-03-2019, 09:36 AM
  #186
Spads11's Avatar
I'll give that a shot. I was pushing one side in (that I could fit a part of my finger and it left a large part sticking up.
Spads11 is offline
Old 11-03-2019, 02:25 PM
  #187
fiveoboy01's Avatar
Same problem here, same solution, push one side down so two sides 180 degrees apart are seated in the groove, install cap. No leaks for me.
It did make me check a couple times to make sure I had the right o-rings!
Spads11 likes this.
Old 11-03-2019, 04:05 PM
  #188
Spads11's Avatar
I checked like 5 times!!!
fiveoboy01 likes this.
Spads11 is offline
Old 11-03-2019, 09:20 PM
  #189
This was the solution recommended for those shock cap o rings
Had the same problem on the 48.4...this was recommended as the solution to getting those o-rings in
Spads11 and Bigv like this.
nitrorig is offline
Old 11-04-2019, 04:05 AM
  #190
erc55's Avatar
Default Steering limiter
The manual says to use one washer and screw on the spindle as steering limiter
but all the setups posted dont use limiters... why is that?
erc55 is offline
Old 11-04-2019, 04:28 AM
  #191
nodrog's Avatar
here's how I mounted my on/off switch, nice and clean with easy access with the body on.
tobamiester and Propchecku37 like this.
nodrog is offline
Old 11-04-2019, 04:34 AM
  #192
speedy2's Avatar
..Because we all like more steering, but they all use the screw at first....
speedy2 is offline
Old 11-05-2019, 03:12 AM
  #193
I know it's early days but is there any other body shell options yet ??
nitrorig is offline
Old 11-05-2019, 04:42 AM
  #194
this is how I set mine up too
Cain likes this.
sp88 is offline
Old 11-05-2019, 05:45 AM
  #195
fiveoboy01's Avatar
Leadfinger has one out. Not sure if itís available for purchase yet, but theyíve released pictures.
