MIP Bypass1 pistons for 1/8th scale >
Like Tree8Likes
Old 09-02-2019, 10:04 AM
  #31
Originally Posted by savage24x View Post
Whatís the diameter of the HB racing pistons? How do they compare to Mugen?
savage24x likes this.
BHutch is offline
Old 09-03-2019, 05:18 AM
  #32
savage24x's Avatar
Originally Posted by BHutch View Post
You are awesome!!!!!
savage24x is online now
Old 09-03-2019, 10:17 AM
  #33
All good but $26 for 4 pistons is a bit much to be honest.
sebtarta is offline
Old 09-03-2019, 10:31 AM
  #34
Eustace is proud of his shit.
largeorangefont is offline
Old 09-15-2019, 06:43 AM
  #35
E1 Diablo's Avatar
Anyone else notice the plastic insert "wrinkle" when you tighten the nut to hold the piston in?
E1 Diablo is offline
Old 09-15-2019, 08:00 AM
  #36
morgoth's Avatar
Do you mean the flap or the bushing?
if itís the flap, you have the piston upside down. If itís the bushing, youíre over tightening it.
morgoth is offline
Old 09-15-2019, 12:31 PM
  #37
E1 Diablo's Avatar
The piston is installed correctly... and it's not over tightened...
Old 09-15-2019, 02:07 PM
  #38
BrokenFrontArm's Avatar
Since there are no pictures to show how the pistons are installed and how the valves are wrinkled, I can only tell from my own experience that the installation instructions that come with the pistons are not very clear, and I installed the pistons upside down for the first time and was wondering why the valves got all wrinkled. Then I watched the instruction and videos from MIP web page again and noticed that the flat side should be facing up, not the side with "MIP" text, after that the valves were nicely flat. As said, I don't know if this is what happened in your case, but worth checking one more time
E1 Diablo likes this.
BrokenFrontArm is offline
Old 09-15-2019, 02:54 PM
  #39
morgoth's Avatar
maybe post a picture because I donít know what the issue could be then.
i donít have problems with my pistons, so I suppose something went wrong during assembly.
morgoth is offline
Old 09-16-2019, 07:54 AM
  #40
E1 Diablo's Avatar
Old 09-16-2019, 08:03 AM
  #41
E1 Diablo's Avatar
I had the piston upside down. MIP text goes to the bottom. Flat side up.
Old 09-16-2019, 08:47 AM
  #42
hyperfuxx's Avatar
Trader Rating: 28 (97%+)
You have the piston right side up? Flange bushing ontop, right?
hyperfuxx is offline
Old 09-16-2019, 09:37 AM
  #43
E1 Diablo's Avatar
See above pictures.
The flange bushings was installed correctly. However, the piston was installed backwards. There is a recess where the kit washer fits into the piston. Itís unlike the kit pistons which has the piston set on top of washer. With the MIP pistons the washer actually sits recessed into the piston. Very easy to make this mistake.
