Like Tree363Likes
Kyosho MP10T
Old 05-26-2022, 05:33 PM
  #436
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 62 (100%+)
strr body will work just have to use the serpent truggy body mounts as the mp10t body mounts are angle the wrong way. i used serpent truggy mounts and took 5mm of the mount to get the correct location i needed. used the serpent etruggy rear mounts to get the body to sit lower as you have to use the lower rear mounting hole only. was a bunch of work but it will fit if you have the time. jconcepts ae body works well also on our truggy. ya i have tried a bunch on our truggy
FLracer and Vtwnpwr like this.
J.Whiting is offline
Old 05-28-2022, 12:48 PM
  #437
Vtwnpwr's Avatar
Originally Posted by Biffff View Post
I have acquired a Strr-e evo2 in a lot of vehicles. I’m curious if the mp10t chassis will bolt up to the strr front and rear clips? I know a lot of parts are compatible….. universals, hubs, shock towers…I know the OG E conversion kit works on the MP10t as well. I’ve read through this entire Thread and haven’t come across an answer? I’m in this truck for cheap…. Original chassis are discontinued. If I know there’s parts to keep it going I’ll keep it, if not I’ll likely just sell it.
thanks
short answer answer no.
the mp10 diffs, blocks are alot smaller the center fits. Universal's will probably work but might pop out eventually unless you use the ST-RR rear hubs maybe.
if the bodies new you'll have to make different mounts to get it to fit.
front carries might hit and lessen your turning radius, found that out the hard way.
Hope this helps.
Vtwnpwr is offline
Old 05-28-2022, 12:59 PM
  #438
Vtwnpwr's Avatar
Originally Posted by FLracer View Post
Love the look Of those STRR bodies …… was hoping they would produce more but it’s not looking like it.
yea, found some on Ebay through Express hobbies they have 7, located in the USA but doesn't ship to the USA. Weird.
Vtwnpwr is offline
Old 06-07-2022, 04:38 AM
  #439
Express Hobbies looks as though they may be located in Canada…just a heads up
FLracer is offline
Old 06-07-2022, 05:29 PM
  #440
Express is listed as though it were in Mahwah , NJ but if you do a search you will find it’s a Canadian shop
FLracer is offline
Old 06-09-2022, 10:56 AM
  #441
hey boss can you post pics on how you mounted the front of your body.
Gioalcala714 is offline
Old 06-13-2022, 11:43 AM
  #442
Who is this aimed at?
Joe H is offline
Old 06-14-2022, 01:27 PM
  #443
If you are referring to the Strr body ….Whiting had discussed using the Serpent mounts. That is back a few in the thread. may have even thrown up some pics. Can’t remember.
if you mean the Pro line Axis body (AE) . Then you will need to space the rear posts out where you want them first….as this will dictate where the front falls.
The Vp pro body body is the same. Tim Wallace discusses this in the thread as well. I think there are also some pics of these bodies if you scroll through the discussion/thread.
the “bruggy” body requires a mounting bracket
I do believe J whiting makes an adapter/bracket to fit the J con “bruggy” to the Mp10t.
Good luck
FLracer is offline
Old 07-06-2022, 10:09 AM
  #444
Vtwnpwr's Avatar
pm sent
FLracer likes this.
Vtwnpwr is offline
Old 07-06-2022, 10:32 AM
  #445
Whose going to run the body Kanai made for the truggy when it becomes available?
FLracer likes this.
Joe H is offline
Old 07-06-2022, 11:00 AM
  #446
Vtwnpwr's Avatar
still not a fan of those bruggy bodies or split batteries.
https://www.hobbymedia.net/13520/kyo...ushless-truggy
Vtwnpwr is offline
Old 07-06-2022, 11:56 AM
  #447
Originally Posted by Vtwnpwr;[url=tel:15918302
15918302[/url]]still not a fan of those bruggy bodies or split batteries.
its all about performance. Give one a try sometime.
FLracer likes this.
Joe H is offline
Old 07-06-2022, 07:14 PM
  #448
That’s just awesome they are releasing the electric version…. Stoked
FLracer is offline
Old 07-06-2022, 10:06 PM
  #449
Mickey_B's Avatar
Trader Rating: 7 (89%+)
Your really gonna be “stoked” when you learn you cannot run a truggy motor.
Mickey_B is offline
Old 07-07-2022, 05:10 AM
  #450
Well….. that’s interesting indeed.
in many pics I see the new Reds can installed.
it is listed as used for buggy/truggy and is 69mm long
it would be a shame to be limited to choices though.
FLracer is offline
