PBS suspension????
Who used it first in first??? |
I believe it was BMT, with the BMT 911 buggy, in both 2wd and 4wd
Originally Posted by 1/8 IC Fan
(Post 15477441)
What is PBS suspension?? looking at that picture of what seems to be an 8th scale (maybe 10th scale not sure) 2wd kyosho i would assume were checking out the front shocks being mounted on the rear of the arm and the rear shocks also being mounted on the front of the arms is completely opposite from what’s normal... also the sway bars front and rear are opposite of what’s normal... very weird set up! I know the new losi 8X rear shocks can be mounted on the front of the arm for indoor so I’m guessing this is an indoor set up correct? Is this what pbs suspension is? |
PBS is "pillow ball suspension" in the front like on the Mugen mbx series and the latest Associated RC8 3.1
Originally Posted by ronsand
(Post 15478736)
Its a BMT 911 1/8 scale buggy, it was the first production buggy with Pillow Ball Suspension, given their use in 1/8 IC Open.
Originally Posted by Matt Piva
(Post 15479098)
lmao my bad. Sometimes things you know can be thrown off by a pic hahaha |
Reminds me back in the 90's where Picco showed their 1st INS-BOX. Pieter Bervoets wrote a column on his MyTSN site that it was a plain copy of the Serpent design, bla bla bla.
Not that long afterwards Picco came with an aswer that Serpent should not whine about copying because Serpent was a master in copying, with that he mentioned the pivot ball suspension on the Serpent Excel which was Serpent its 1st car with pivot balls that it was copied from Picco cars. |
