Clutch bell and spur too far to mesh. Help! >
Like Tree2Likes
  • 1 Post By BHutch
  • 1 Post By UrabusDenis
Old 06-13-2019, 02:26 AM
LoudOne's Avatar
Trader Rating: 31 (100%+)
Default Clutch bell and spur too far to mesh. Help!
Good morning.. Iíve been upgrading my Serpent 811 RTR and the only thing left is the Novarossi engine that gives away the fact that it was once an RTR. I installed a Novarossi clutch with 13T bell and cannot get it close enough to the 46 spur to mesh. Do I need a much bigger spur or bigger bell? I even tried a 48 spur and itís still too far. Any help/guidance is appreciated.
LoudOne is offline
Old 06-13-2019, 03:16 AM
Trader Rating: 21 (100%+)
Seeing as normal gearing is 13/48 I wouldnít quikly assume 46 is incredibly small but I think itís more in the electric gearing range which makes me think your clutch Bell would need to be bigger but Iíve never ran electric or a serpent to tell you forsure if those are infact different then stock. I would check there tho and make sure your center diff gear is same as stock cause it sounds wrong.
Matt Piva is online now
Old 06-13-2019, 03:29 AM
Use the 48T spur with the 13T Serpent original bell.
what engine mounts do you have? If they are the RTR blocks it does not give you any play. If so purchase these
https://www.absolutehobbyz.com/Serpent-Engine-Mount-2pcs_p_494011.html
that will help with the mesh. Let us know the outcome
sebtarta is offline
Old 06-13-2019, 06:36 AM
Big Will's Avatar
Sometime raising the engine can help. It might be to low to actually hit the spur. The new mounts should help but check if its sitting at the right height as well.
Big Will is offline
Old 06-16-2019, 07:31 AM
Not sure about the RTR but the serpent SRX8 line of buggies has their own clutch bells and spurs that are designed to not need mesh adjustment. Try the Serpent clutch bell and it should be a better mesh.
LoudOne likes this.
BHutch is offline
Old 06-16-2019, 11:30 PM
UrabusDenis's Avatar
I am pretty sure something else is the issue since that is very normal gearing, maybe check in the 811 forum for help? However if that really is the case (I am unfamiliar with the car) take the chassis to a machinist shop to enlarge the engine or center diff slots
LoudOne likes this.
UrabusDenis is offline
