Starter box replacement motor >
Old 06-07-2019, 12:30 PM
Default Starter box replacement motor
So I am trying to replace the two motors in my starter box (blue ofna starter box) and the pinion that is on the motors does not have a set screw to remove them. Is there a way to get this pinion off so that I can put it onto the new motor? Or do I have to buy a motor that already has a pinion on it?
Also does anyone have any advice about which type of motor to replace the stock motors with? My current motors did not last as long as I would have hoped for them to last.
Thanks!
BHutch is offline
Old 06-07-2019, 01:08 PM
Roelof's Avatar
775 Motor w/ Pinion Gear for 10244T Starter Box #92870 [10244]
https://www.ebay.com/p/OFNA-Racing-9...244/1905582063
partnumber 92870
Roelof is offline
Old 06-07-2019, 01:31 PM
Thanks for the quick reply and links!
BHutch is offline
Old 11-11-2019, 03:57 AM
UrabusDenis's Avatar
Hi guys, did anyone successfully replace the pinion gears with "normal" hobby grade grub screw pinions? I'm looking to resurrect a dead box with 2x 21T or 27T 540 motors I have laying around. The specs should be good, but I'd need the pinions. What pitch are these gears?
UrabusDenis is offline
