Like Tree54Likes
Agama A319
Old 06-22-2019, 11:35 PM
  #31
Trader Rating: 65 (100%+)
Default Helping
I was just trying to give people a heads up that may not know is all. As well as the top plate on the center diff. Don't over tighten or your brake cams will bind. This maybe some people first build. So i offering any advice i can. Not saying you didn't know this already Sorry if i offended you
mixedguy is offline
Old 06-22-2019, 11:36 PM
  #32
Default 25 years
Captain club. That is funny. Been racing on and off for 25 years. I am on the team and just trying to help is all. If someone comes across a issue
mixedguy is offline
Old 06-22-2019, 11:47 PM
  #33
Default Mistake
Sorry thought am message was directed at me Was not paying attention close. in the middle of 319 build lol
mixedguy is offline
Old 06-24-2019, 08:42 AM
  #34
Originally Posted by Ulch View Post
Anyone know if there are any stock setup suggestions out for the 319? Iím building mine now and I was curious about pills and geometry. Thanks!
Be sure to follow the setup closely
PDF instruction manual up soon.
Ulch likes this.
Mark Rumble is offline
Old 06-24-2019, 07:28 PM
  #35
thank you!
Ulch is offline
Old 06-29-2019, 11:14 PM
  #36
The 319 is legit. Ran it Friday and Saturday at my home track Flowood RC. Itís generates at lot more grip than the 215sv especially in the rear end. Itís got that locked in feel that makes it easy to drive but it will also rotate. The gearing creates a lot of forward bite and it shoots out of corners straight and fast. Iím not an expert but my times were in line with some of the guys that are a good bit faster than me. Buy the car...you will not be disappointed.
underway, FastPete and mckibbint like this.
Ulch is offline
Old 06-30-2019, 04:54 AM
  #37
I also drove two different A319 this weekend both were team drivers and i must say i was impressed. The car had so much steering but still rotated. You could drive under about any car on the track. I am considering buy one since my current platform is worn out.
FastPete likes this.
jwilhelm is offline
Old 07-01-2019, 08:25 AM
  #38
AGAMA A319 Manual Link Below:
https://cdn.shopify.com/s/files/1/00..._2019_Small?38
Old 07-03-2019, 03:01 PM
  #39
marshon50's Avatar
page 11 sig4318 on the caster links is correct on the tower side, incorrect on the caster block side....sig4324 maybe...... Also the plastic spacer on the caster block needs to be removed up top at the mounting holes.
marshon50 is offline
Old 07-04-2019, 11:49 PM
  #40
am
Are the diffoutdrives supperted by a bearing on the outside in the gearbox? Mugen had that on the old Mbx4. If so, thats awsome!
am is offline
Old 07-05-2019, 06:01 PM
  #41
Mickey_B's Avatar
Trader Rating: 7 (89%+)
Great until you have to service and buy new bearings.
Mickey_B is offline
Old 07-05-2019, 06:46 PM
  #42
Trader Rating: 127 (100%+)
Have troubles with yours?
ROSCOE is offline
Old 07-05-2019, 08:19 PM
  #43
Mickey_B's Avatar
Donít own one and prolly never will. This is just feedback I hear from people that run the buggy.
Mickey_B is offline
Old 07-06-2019, 10:39 AM
  #44
frewster's Avatar
Might want to fix the file so it has the proper ".pdf" extension.
frewster is offline
Old 07-06-2019, 03:30 PM
  #45
Trader Rating: 53 (100%+)
never an issue and i didnt even run the outdrive boots... the diffs are bullitt proof. just dont forget the lil half moon piece to close up the rear bulkhead...
underway is offline
