M2C SHOCK PISTONS AND BLEEDER CAPS!!
Mitch is an awesome guy with amazing products ... show him all the support you can ... M2C RACING !!
the plural is chassis
hey bud
hey bud
Any feedback ?
I tryed last sathurday M2C o-ring pistons and ZRS shock caps and very awesome
Mitch, any chance you could do some ZRS for the Soar buggy?
An option for you may be find someone who upgraded and try their caps on your shocks. I know most inter change with little to no mods as these caps have a very short threaded section. I've been running the oring pistons and the ZRS caps for about a month or so working with Mitch personally trying develop a few more setup options with both of these items. Awesome guy, absolutely the only person who ever took the front end off my buggy while I was marshaling!!! Funny times! Truly a unique individual
so looking at m2c pistons, I only find 8x1.2 for nt48.3, however looking at tekno's setups lutz,fischer,bornhorst seem to run 8x1.3. with that 1.2 really feel that different? and another thing on m2c's site they state recommended using 300-400cst oils however they all run seems 600+ anytime so going by a tekno setup, these pistons would'nt work right?
m2c9657 16 MM 8 HOLE 1.2 THRU HOLE
That being said, I have not ran the pistons with the bleeder caps yet, only the pistons and everything I heard is that the caps really take the pistons to another level...
It definitely brings the car as a package to a whole other level!!! Currently been playing with custom piston configurations, more commonly found combos that is. Personally the 6 hole pistons are a favorite. I've been trying tapered, split hole sizes, and multi hole tapers... it sounds overly complicated, but mainly it's just 6,8,10 hole pistons with varying combos of tapered holes and split hole sizes. The best all around piston for medium grip tracks has been a 6 hole with 3-1.2mm holes and 3-1.4mm holes. I've done 2 variations with tapered holes as well. But standard 6-1.3 pistons have become a go to favorite. I personally like a heavier shock oil than what's suggested. But it's mainly a guide line and you can run or use any weight oil necessary to get the proper feel. Different cars geometries, need or want different weight oils. For instance 3-2.1 pistons feel amazing on a tekno .4 with 40/35 oils. Same package in a Mbx7r needs 50/45 for roughly the same feel on the track. All due to geometry. Or at least that's what I've found for myself.
