Tire Mounting, 'BK Beadlock' >
Old 02-01-2019, 10:48 AM
Moderator
mxwrench's Avatar
Default Tire Mounting, 'BK Beadlock'
Thought I'd share this with you guys.
mxwrench is offline
Old 02-01-2019, 01:22 PM
Trader Rating: 21 (100%+)
https://youtu.be/rBFkdBvP31U
hmmmm. Ok Iíll try it and see whatís up with this, one things forsure you will not lose a tire to ungluing. I may go 1 loop on a set and normal on another just to feel side wall differences, that would be my only question, could something as small as that twisted part going to cause any ripping of the tire (could glue tape over it) and will the thicker two loops cause any kind of feel or would it be totally unnoticeable? I personally never have tires unglue, I use a dremel on the wheel and tire to get fresh warm rubber right before I glue, I donít even have to clean after the top layers gone and use lock tight ca glue with 100% success so far (20+sets) but I like the extra safety of the lock tie around the outer part. So I will try.
for anyone that wats to see quickly, hereís a picture of this mans idea.
Matt Piva is offline
Old 02-01-2019, 01:26 PM
