-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   HB Racing D819 Nitro Buggy (https://www.rctech.net/forum/nitro-off-road/1034429-hb-racing-d819-nitro-buggy.html)
jersey 01-12-2019 09:01 AM
TRiN 01-13-2019 01:25 AM
HB204439 HB RACING Diff Input Gear (13-43/Light)
HB204440 HB RACING Input Gear Shim Set (8pcs)
HB204441 HB RACING Dogbone 85mm
HB204442 HB RACING Dogbone 118mm
HB204443 HB RACING Transmission Conversion Kit (D817)
HB204444 HB RACING Front Sway Bar Set V2 (2.3, 2.5mm)
HB204445 HB RACING Rear Sway Bar Set V2 (2.5, 2.7mm)
HB204450 HB RACING D819 1/8 Competition Nitro Buggy
HB204451 HB RACING D819 Decal
HB204456 HB RACING D819 Swaybar Pivot Ball v2 set
HB204458 HB RACING D819 1-pc Swaybar Link (2pcs)
HB204459 HB RACING M2.5 x 12.4mm Pin (4pcs)
HB204461 HB RACING One Piece Engine Mount (D819)
HB204463 HB RACING D819 Hub Carrier Arm v2 no.3 (4pcs)
HB204464 HB RACING D819 Hub Carrier Arm v2 no.4 (4pcs)
HB204465 HB RACING D819 Hub Carrier Arm v2 no.5 (4pcs)
HB204466 HB RACING Engine Mount Adjuster no.1 (4pcs)
HB204468 HB RACING Engine Mount Adjuster no.3 (4pcs)
HB204470 HB RACING S15 Buggy Bodyshell Standard (HB Racing D819 - JConcept)
HB204471 HB RACING S15 Buggy Bodyshell Lightweight (HB Racing D819 - JConcept)
HB204472 HB RACING HB Megabite Mounted Tire (Yellow Compound/White Wheel/1:8 Buggy)
HB204476 HB RACING Arm Mount 2-dot (B/+0.7mm)
HB204478 HB RACING Lightweight Wheel Hex Hub 2pcs (Narrow)
HB204479 HB RACING Brass Wheel Hex Hub 2pcs (Narrow)
:tire:
Motorman007 01-13-2019 03:39 AM
:tire:
Where did you find the part numbers?
Thank you for your
TRiN 01-14-2019 01:20 AM
https://cimg8.ibsrv.net/gimg/www.rct...11159ed58f.jpg
:tire:
Eastside777 01-14-2019 03:39 AM
It appears to be the same car again. Very minor changes.
fbrk8r 01-14-2019 04:22 AM
Yes. Thank goodness! LOL
Big Will 01-14-2019 05:18 AM
I was really hoping for new C & D blocks. Captured hinge pins. New front spindles with pills to go from 15 - 17.5 - 20 degrees. Not sure if other things need changes.
fbrk8r 01-14-2019 05:56 AM
Agreed
RePeTe 01-14-2019 06:22 AM
not liking the gearbox change, I liked the dogbone going into the pinion. box art shows the normal style drive cup.
Ricardo_d99 01-14-2019 06:28 AM
agree and also they didnít go for the wider C & D blocks and the short arms like the ones they were using at the worlds .
fbrk8r 01-14-2019 10:04 AM
I like it as well, but I would like to see something change about the shims. It seems like every time I pull my pinion out, there is some sort of shim damage. Maybe whatever change they make will correct this.
rjmakk 01-14-2019 10:17 AM
looks like it doesnt come with front springs? hahah
lilstewie 01-14-2019 11:05 AM
Looks like a diff cup coming out of the gear box for the drive-line (at least the rear that is visible) using a (shorter?) dogbone. That would solve that shim/c-clip issue on the others. I hate changing/cleaning those bearings.
RePeTe 01-14-2019 11:23 AM
I haven't damaged a shim yet, but did forget about them and was confused on why I couldn't get the damn gear out. once I removed them it came right out. Surprisingly my bearings are still the original ones on the pinion gears, on both my e and d817, both are first shipment buggies. I just love the fact that there are no set screws on the drive train, easily the most dependable setup on the market.
TRiN 01-14-2019 12:14 PM
Lightweight drivetrain conversion kit for D817
https://cimg1.ibsrv.net/gimg/www.rct...d8d9836d75.png
:tire:
