HB Racing D819 Nitro Buggy >
Like Tree114Likes
Old 04-04-2019, 10:42 AM
  #121
Mickey_B's Avatar
Trader Rating: 7 (89%+)
Originally Posted by Big Will View Post
Whats the deal with Fastrace? Why are their caps and bladders so "good"? The bladders look like Serpent bladders. (At least the ones with the Cobra kit)
All marketing hype. Pretty simple Ongaro uses them and wins so people think that by emulating and running them they will be winners as well.
Mickey_B is offline
Old 04-04-2019, 10:49 AM
  #122
Big Will's Avatar
Originally Posted by Mickey_B View Post
All marketing hype. Pretty simple Ongaro uses the and wins so people thing that by emulating and running the same set up they will be winners as well.
Maifield uses them as well, I think.
Big Will is offline
Old 04-05-2019, 08:21 PM
  #123
so does David ronnefalk
shark2288 is offline
Old 04-06-2019, 12:20 AM
  #124
RCSureStart's Avatar
Default D819 Transmission o-rings
You may have noticed when purchasing the D819 transmission kit that it doesn’t come with the o-rings that sit in the outdrive.
The D819 exploded diagram says that the part number for this is the diff o-ring (HB-204027) but I’ve found that this part is too big for the outdrive and doesn’t sit properly.
After speaking to the distributor in the U.K. we’ve found that the correct part number should be HB-66595
https://www.futureworldmodels.com/Mo...cs-c2x28763368
RCSureStart is offline
Old 04-08-2019, 01:55 PM
  #125
TruggyStyle's Avatar
Hi Guys,
what is the difference between the D817 No.5 and D819 No.5 Rear Hub Plates?
Any Chance how I can identify all my different D812, D815, D817 and D819 Rear Hub Plates and Steering Block Arm Sets?
Do the parts have different markings?
TruggyStyle is offline
Old 04-09-2019, 04:03 AM
  #126
Trader Rating: 14 (100%+)
Originally Posted by TruggyStyle View Post
Hi Guys,
D817No 5 plate. Take that plate. Remove the camber link hole to the inside. Then add a new hole to the outside and u have the new D819 plate.
So the D817 plate outer and middle hole is the exact same as the D819 middle and inner hole. And the D819 has a new hole even further to the outer direction.
Buckland and TruggyStyle like this.
Flipnsticks is offline
Old 04-09-2019, 04:04 AM
  #127
Hi Guys,
each plate should have little drill point detente in the carbon. This identifies the plate number. 5 drill point marks is a plate 5.
Same for rear hub plates and steering plates
TruggyStyle likes this.
Old 04-12-2019, 08:26 PM
  #128
Trader Rating: 36 (100%+)
Getting rdy to pick up a nice used e817v2 and was curious what size clutch does the d817/819 use? 32 or 34mm? Thanks
CRaZeD is offline
Old 04-15-2019, 06:20 AM
  #129
Big Will's Avatar
E817v2 is an Electric buggy. The D817/819 uses a 34mm "flywheel"
Big Will is offline
Old 04-15-2019, 05:05 PM
  #130
Trader Rating: 50 (100%+)
This being the nitro thread I had a question regarding the Ebuggy and the new D819 drive-line upgrade. Think I made a slight overlook on my part, apparently to make this work I would have to purchase the nitro ring gears?
GettinLapped is offline
Old 04-16-2019, 01:41 PM
  #131
the e817 and d817 have completely different center drive lines. You would need new center shafts aswell, which im not sure exist
RePeTe is offline
Old 04-17-2019, 09:34 AM
  #132
Big Will's Avatar
D817/D819 ring & pinion are 43/13 E817 are 43/10. so the ring gear is the same but the pinion are not. Not sure how going to a 13 tooth pinion will effect the car.
Big Will is offline
Old 04-17-2019, 10:33 AM
  #133
Motorman007's Avatar
Trader Rating: 89 (100%+)
D817 gearing and pinion part number
HB Racing Differential Ring & Input Gear Set
HBS114743
THIS IS NITRO Gearing to make it
This place has what you need AMAIN is out.
https://www.absolutehobbyz.com/Hot-B..._p_506799.html
This is EBuggy
HB Racing Differential Input gear V2 (10T)
HBS204038
HB Racing 43T Differential Ring Gear (For 10T Input Gear)
HBS204195
The ebuggy gearing is 43/10 its gearing is Truck gearing. So some of the team members are and have been running the Nitro gearing. The cut on the ebuggy ring and pinion is not the same as the ring and pinion on the nitro that is the reason why you can not just change the pinion and you are good. You have to change it all.
and one you go to the nitro gearing you have to change your pinion too 15, 16, 17, 18 depending on motor
FROM D.R.
HB Racing: What was the key advantage the E817 V2 gave you?
David Ronnefalk: The most important thing you needed was the car to handle the bumps very well. With a great shock package the car really felt amazing out there and it was very smooth over the bumps and it didn’t get upset when you got off the line, which was a key.
HB Racing: Have you made any special modifications or settings to the car?
David Ronnefalk: I think the major difference on the car is that I used the 43/13 nitro gearing inside the gearboxes. Normally I prefer the standard 43/10 E817 V2 gearing because it gives more punch coming out of the corners, but for the very rough DNC track I went with 43/13 to get more throttle control.
HB Racing: What option parts did you use?
David Ronnefalk: This time I must say the car was very much stock. For option parts I used the hard suspension arms, and for this track I also had the optional 2.75 degree toe in the rear. For the rear hub plates I used #5 from the 817 series. Other than those and the nitro 43/13 gearing, the car was a standard E817 V2.
I HOPE THIS HELPS SIR
Motorman007 is offline
Old 04-17-2019, 11:38 AM
  #134
HBS114743
This is EBuggy
HBS204038
HBS204195
FROM D.R.
Yes, very informative thank you.
Old 04-25-2019, 04:41 AM
  #135
@Flipnsticks thanks for you explanation. I think some of my Carbon Steering Plates are very old. If I remember correctly they are from a D812 and they have no markings on them.
Is anybody running a OS Motor in his D819? I build my OS B21 Adam Drake in the Car and the gearmash is way to tight. I used the Stock No.1 Plates (orientation: loose) and 13/48 Gearing. The Drivetrain is binding up completely.
I think the Crankshaft of the OS is higher compared to a Orion CRF or Performa Engine.
What is the best Solution for this Problem?
No.2 Plates for the Motor-Mount or should I try to get my Engine a little bit down (0,2-0,5mm).
