HB Racing D819 Nitro Buggy >
Like Tree45Likes
Old 02-15-2019, 05:30 AM
  #76
samuelsonmark71's Avatar
Trader Rating: 22 (100%+)
Reds clutch personally, the thing lasts forever and keeps bearings intact!
samuelsonmark71 is offline
Old 02-16-2019, 11:45 AM
  #77
Same here. Love it!
Ayreon is offline
Old 02-16-2019, 11:31 PM
  #78
Arctic RC's Avatar
Does the new engine mount and engine mount adjusters work with 0.8 mod spur and clutchbell?
Arctic RC is offline
Old 02-18-2019, 02:34 AM
  #79
roblupo's Avatar
Anyone know or heard when the updated parts will be in stock? I know the kits are in stock, but the updated parts that are included I have not seen. Thanks
roblupo is offline
Old 02-18-2019, 04:44 AM
  #80
yes, however u may need a set of adjusters sold as option parts. The kit does not come with all of them.
Arctic RC likes this.
Flipnsticks is offline
Old 02-21-2019, 04:38 AM
  #81
Is the box setup a good Starting point or is there a basic setup that most of you guys run?
Slablabtx likes this.
shark2288 is offline
Old 02-26-2019, 09:54 AM
  #82
Big Will's Avatar
So I started my build last night. I got the diffs together and the front & rear felt fine (like new diffs). The center though, felt bad! While turning the outdrive by hand there is one spot that is pretty bad and needs to be forced to move past.I know the O.S. Speed will never notice it and it will probably break in after awhile but it seems like there is something not aligned correctly.
Big Will is offline
Old 02-26-2019, 10:14 AM
  #83
nitro_mt_racer's Avatar
Trader Rating: 225 (100%+)
If it feels that bad I'd take it back apart and see what the issue is. Probably a cross pin that isn't fully seated.
nitro_mt_racer is offline
Old 02-26-2019, 06:51 PM
  #84
wfo
wfo's Avatar
Answer rc will have them! shows none in stock as of today.
wfo is offline
Old 02-26-2019, 07:03 PM
  #85
wfo
wfo's Avatar
looked again, some new parts are in stock! you'll have search for them in the d817/d819 sub categories.
wfo is offline
Old 02-27-2019, 07:52 AM
  #86
Big Will's Avatar
I have the front end and center diff done and mounted to the chassis. When I spin the axles it feels even worse in the car then it does out of the car. I'm going to have to take it apart. I feels like the spur gear is hitting the chassis but its not. So weird. The front diff feels really smooth, btw.
Big Will is offline
Old 02-27-2019, 08:06 AM
  #87
the center diff.
1. Remove from car
2. Get a feel for it
3. Loosen the 4 screws 3/4 turn each.
4. See if it feels better, this just gives u an idea if pressure is affecting it
5. Take it apart
6. Was blue gasket installed?
7. Are both cross pins fully seated?
8. Are both the 2 larger gears fully seating with nothing under them rubbing?
9. Correct what u find
10. Rebuild
11. If not smooth and still catches just a little, run it for 5 to 10 minutes in the car at the track. Check it. Likely will be good to go from here.
nitro_mt_racer likes this.
Old 02-27-2019, 04:03 PM
  #88
Lightbulb
D819 Blank Setup Sheet
D819 Base Setup Sheet
D819 Exploded View
D819 Instruction Manual
TRiN is offline
Old 03-01-2019, 07:13 AM
  #89
Big Will's Avatar
I found the problem I had. The shim behind the pinion in the front gear box needed to be removed. It was binding everything up. Now thats it's out it all spins nice and smooth.
lilstewie and duncan520 like this.
Big Will is offline
Old 03-02-2019, 01:46 PM
  #90
wfo
wfo's Avatar
Can someone give insight to this new D819 part,( 2 dot B/+0.7mm) block. will it provide more front kick?
wfo is offline
