HB Racing D819 Nitro Buggy >
Like Tree112Likes
Old 11-24-2022, 06:34 PM
  #451
jpz_67's Avatar
Trader Rating: 56 (100%+)
Originally Posted by MXRCF1 View Post
If I remember correctly steering plate #1 has least akerman #6 most?
On the rear hub #1 plate highest roll, #5 lowest roll?
I go by feel.
Lower number on plates in front is more steering.
Lower number in rear plates gives the car more grip.
jpz_67 is offline
Old 11-24-2022, 07:53 PM
  #452
Suspended
Default HB steering and rear hub adjustments...
Originally Posted by jpz_67 View Post
I go by feel.
Does anyone know the Akerman and roll center differences of the plates? Thanks for your response; I am looking for a more detailed explanation, however.
MXRCF1 is offline
Old 12-07-2022, 08:14 PM
  #453
1evo RRR Driver's Avatar
Fellas quick question for those that have changed to CVD out back…..
what parts are needed? Besides the CVD of course ……. I.e different bearing size?
thanks
1evo RRR Driver is offline
Old 12-08-2022, 07:10 AM
  #454
jpz_67's Avatar
thanks
Nothing sir. They fit the same as the universals but they rest inside the rear inner bearing. They will create more rear grip and less roll but suffer in the bumps. If you are on a smooth track with grip they are for sure faster. I have just got used to universals everywhere so I stick with them.
1evo RRR Driver likes this.
jpz_67 is offline
Old 12-27-2022, 09:35 PM
  #455
Default 4 shoe clutch setup
Just ordered the 4 shoe and curious as to what shoes and springs everyone is using? Also, what springs and shoes other than hb are people using with this clutch? Thanks
Goslo22 is offline
Old 12-28-2022, 01:25 PM
  #456
Suspended
Default HB4shoe
Delete
MXRCF1 is offline
Old 01-12-2023, 07:39 AM
  #457
fux
HB Racing Front suspension arm set (2pcs/D8 Evo) HB204840 | HB Racing
And several other parts of D8T are available after the worlds.
fux is offline
Old 01-12-2023, 08:13 PM
  #458
New upgrade coming.... I have a question.
Is the chassis hard coated? Because a lot of parte are hard coated but i m not sure if all black piece are hard coated. Thanks
turboboost is offline
Old 01-14-2023, 10:20 AM
  #459
Doe anyone have a good set up for high grip astro.
wreckingball is offline
Old 01-28-2023, 09:34 AM
  #460
wfo
wfo's Avatar
I have a new 50t spur from my truggy but I need to change out my spur on the nitro buggy. Can a use the 50t in place of my 48t ,what will the result be? More bottom excelleraton.
wfo is offline
Old 01-28-2023, 07:53 PM
  #461
stanleyw808's Avatar
Hello wfo,
Yes.. You will get more bottom end but shorter top.. Be careful if the track has a long straight..
Cheers..
wfo likes this.
stanleyw808 is online now
Old 01-30-2023, 07:11 AM
  #462
jpz_67's Avatar
Yes, it would get a lot more punch. You could always go 14/50 and split the difference.
wfo likes this.
jpz_67 is offline
