HB Racing D819 Nitro Buggy
#406
If you look at the pills, they are shaped like an arrow. If they both point in the same direction (both in or both out) toe at the hub is 0*, one orientation is wider and one is narrower. If the two pills at the same hub point in opposite directions, I believe it adds 0.5* of toe at the hub. Just make sure the "wide" one is in the rear position so you get toe in and not toe out.
Oh......how is the book setup on the 17v2?...did the factory miss the setup?
#407
Does hb offer a steel shock standoff for the front of the 819rs. All I can find is the aluminum /light weight one. With my brutal driving I would rather have steel. I purchased both buggies used and they had steel standoffs on it. Just can't seem to find them. Any help would be appreciated
#408
#409
Ok another parts question. Looking for the steering block bushings part# 204568. Can't seem to find any. If anyone knows where to find or has some they wanna sell let me know. Thanks
#410
That part number had been discontinued correct part is
#204656
#204656
#411
#412
Answer rc has them in stock.
#414
#416
should go together like any other engine mount. Just make sure you put the bottom cams in the loose direction at first until drivetrain breaks in. Please be more specific what issue you’re referring to
