HB Racing D819 Nitro Buggy >
Like Tree114Likes
Old 03-28-2021, 12:39 PM
  #301
Originally Posted by ceh329 View Post
Does anyone know if any other manufactures diff housing can be used in the HB? I'm getting real tired of the diff housing leaking. I have glued them and still have the problem. They don't last, I never had this problem with Kyosho.
assume you're talking about the point between cases and the crown gear?
Most leaking will come from the case not being flat or leaking through screw holes.
I had terrible issues on a JQ centre diff and the fix was sanding the case, using TWO gaskets and tightening the screws hard.(I tried 3 new cases, but typical JQ quality)
MonsterJuice is offline
Old 03-28-2021, 03:03 PM
  #302
Kyosho Kid's Avatar
I used to use Mugen gaskets when i had JQ. Worked perfect. Also if you overfill the diff it will leak.
Kyosho Kid is offline
Old 03-29-2021, 07:26 AM
  #303
ceh329's Avatar
My leaks are coming from the sealed side ( not the gasket ) of the diff housing. there have been a few videos about using tire glue to make a better seal. I have tried this but it still leaks. I really thought about buying the Fioroni but its like $50 a piece.
ceh329 is offline
Old 03-29-2021, 12:44 PM
  #304
HaulinBass's Avatar
Trader Rating: 16 (100%+)
If hb is still using the same diffcase from the d8 series a kyosho 777 diffcase is almost a perfect match
ceh329 likes this.
HaulinBass is offline
Old 03-29-2021, 05:55 PM
  #305
Kyosho Kid's Avatar
Maybe you didn't use good grease on your diff cup and o-ring?
Might need to replace them.
Old 03-30-2021, 03:18 AM
  #306
Default Considering a D419
Hi all,
A number of D419 buggies run at our track and they go really well.
I currently run a TLR 8ight-X Elite. I was wonder what is the durability of the HB buggy was like as well as what are the suggested hop-ups?
Thank you.
GS76 is offline
Old 03-30-2021, 07:01 PM
  #307
ceh329's Avatar
The D819 is a tank. Super durable, and as for option parts, the car is solid right out of the box. I would suggest investing in Hard Arms, Rear Carbon arm insert and aluminum servo horns. If your track is high bite you might want to pick up a few of the other option parts like 2.75 degree rear D block. Oh Yeah, last but not least, VPR Pistons and P1 bladder shock caps.
ceh329 is offline
Old 04-11-2021, 11:54 PM
  #308
ceh329's Avatar
Does anyone else make replacement clutch shoes for the stock HB 3 shoe fly wheel?
ceh329 is offline
Old 04-14-2021, 12:13 AM
  #309
Kyosho Kid's Avatar
You can use any 3 shore really.
I've used Mugen and JQ.
Old 04-14-2021, 05:30 PM
  #310
ceh329's Avatar
Are you using the JQ or Mugen flywheel as well??? The reason I ask is I'm running the MOD 0.8 gears
ceh329 is offline
Old 04-15-2021, 07:07 PM
  #311
Kyosho Kid's Avatar
I use whatever flywheel I want with whatever shoes. For you it is clutch bell specific. The main difference between them all is width and weight. HB shoes use that little spring though. Others use the traditional style spring. If you can't get HB shoes, i'd get Mugen hard shoes.
Old 04-15-2021, 10:03 PM
  #312
stanleyw808's Avatar
Hello ceh329,
You could try S-Workz Clutch Shoes..
Cheers..
stanleyw808 is offline
Old 05-26-2021, 04:41 AM
  #313
LoudOne's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Cajvol94 View Post
Will any other manufacturer bodies fit the D819?
reason as I have many others just sitting around. Thanks
Absolute Hobbyz sells Lead Finger and they’re truly the best.
LoudOne is offline
Old 07-05-2021, 09:14 AM
  #314
Suspended
Is there a new car coming soon? The RS is discontinued already?! Also what receiver pack fits well?
thanks
sn47som1 is offline
Old 07-07-2021, 10:30 PM
  #315
Hello, everyone.
Which chassis brace do you use?
Aluminum? Plastic?
CJWRACING is offline
