HB Racing D819 Nitro Buggy
#16
Is this HB204443 HB RACING Transmission Conversion Kit (D817) ?
#17
I haven't damaged a shim yet, but did forget about them and was confused on why I couldn't get the damn gear out. once I removed them it came right out. Surprisingly my bearings are still the original ones on the pinion gears, on both my e and d817, both are first shipment buggies. I just love the fact that there are no set screws on the drive train, easily the most dependable setup on the market.
#18
15x21x0.1
shims
shims
#19
#20
#21
did he use 4 shims between the bearings and 2 spring clips on outside of pinion?
What is the white paste he used? White lithium grease?
#22
#23
hi all!! I am the author of this video, I use 4 15x21x0.1 shims behind the large bearing and one original shim behind C clips!! I do this on E817 after a lot of problem with shims and now after 8 month it seems very very good.
I hope you like this video
#24
#25
The question is where can we find the 15x21x0.3 shims in the USA. I found some in China
https://www.ebay.com/itm/100Lots-Rep...r=571887292077
#27
#28
Also hear in italy it's very difficult to find
I take it in UK from ebay. If you click the video link you will find an ebay link in the description.
#29
The total thickness must be 0.4 mm
#30
Is this the right part for those shims? Absolute Hobbyz. Plus you get more clips. Part no. 114762
Input Shaft Clip
Input Shaft Clip
