HB Racing D819 Nitro Buggy >
Like Tree114Likes
Old 07-17-2020, 10:46 AM
  #256
Trader Rating: 81 (100%+)
Originally Posted by MacMcGarrigle View Post
Just heard that the D819 parts are back portable to the D817. Can anyone confirm that?
cheers,
Mac
Most parts are but NOT all of them. Examples - Ring and Pinion Gear
Buckland likes this.
tom73 is offline
Old 07-21-2020, 09:06 PM
  #257
Default D819 upgrades
Just curious, but I知 looking to upgrade my d817v2 to some d819/D819rs parts without having to buy the full kit. I have the D819 driveline already, but would the RS v3 shock towers work on the 817v2? Any suggested parts that you guys personally feel made a difference like maybe the one piece mount? Any help would be great! I absolutely love this car and I知 not trying to look cheap but if I could make a d819rs without getting the -2mm chassis I would be super happy to invest in the parts to do so!
thanks!!
Teknosammy is offline
Old 07-22-2020, 05:10 AM
  #258
thanks!!
Only parts I would get would be the 2 degree knuckles and the rear tower for the tuning options. The one piece mount is a bit of a personal preference, some prefer the older mount. The shorter chassis isn't a big difference unless you are running really low rear toe and want to keep the wheelbase similar to the old car with 3 degrees toe. The front hub spacers are nice to have but anything else is durability improvements that may just be worth getting if you break something in the first place or are replacing some parts due to wear.
Scroggie is offline
Old 07-22-2020, 02:49 PM
  #259
Awesome! Thanks for the suggestions! I値l look into right away for myself!
Old 07-29-2020, 02:59 AM
  #260
Trader Rating: 351 (100%+)
I want to ditch the engine mount inserts. Do anyone know engine mount screws I could use?
jmoneym is offline
Old 07-29-2020, 10:38 PM
  #261
Kyosho Kid's Avatar
Why? It works perfect.
Kyosho Kid is offline
Old 07-30-2020, 05:10 AM
  #262
pballer2777's Avatar
Trader Rating: 28 (100%+)
possible he would like to use a different tooth clutch bell?
pballer2777 is offline
Old 07-30-2020, 02:55 PM
  #263
Yes, to avoid buying all the inserts for different mesh.
jmoneym is offline
Old 08-01-2020, 07:08 AM
  #264
Is anyone running an external fuel filter? If so, how have you mounted it and routed your lines...
thanks
Jaf1977 is offline
Old 08-06-2020, 07:43 PM
  #265
I have let it , and replace the engine mounts by the 817 part HB67366 , easier to have a perfect mesh !
maximax is offline
Old 08-14-2020, 09:11 AM
  #266
speedy2's Avatar
speedy2 is offline
Old 08-20-2020, 04:48 AM
  #267
Zerodefect's Avatar
That's crazy. Those inserts are solid gold. Less, or no thread lock. No more cm cutting up my bolts with a Dremel when they strip out from being too tight, too thread locked, or mesh reset too many times.
Xray uses a giant button head that might work, if you have MIP Allen drivers. Anything less strips them out.
Kyosho Kid likes this.
Zerodefect is offline
Old 08-20-2020, 07:54 AM
  #268
Kyosho Kid's Avatar
10000000000000%
never comes loose or moves. Super solid. As long as all things remain the same you never have to adjust mesh. I did have to switch to #2 inserts to run REDS clutch bells though. No big deal. Solid and reliable.
Old 08-31-2020, 05:49 AM
  #269
Originally Posted by speedy2 View Post
I did a "dry fit" test with these new quick-change gear boxes.
Here are some pics to get an idea how they look on the car.
K1LLRAD is offline
Old 08-31-2020, 10:29 AM
  #270
ROSCOE's Avatar
Trader Rating: 130 (100%+)
Those quick change cases make AVRCs look real good!
ROSCOE is offline
