HB Racing D819 Nitro Buggy
#211
If any damage occurred, it would be at the bottom of the mount and just the threads. As long as the mesh is good for you the inserts are fine.
As far as the extension, the plug might be marked. Consult your owners manual for the polarity. I had the same issue. All black wires on my protek servo going into my KO receiver. Should be fine but if you look at the plug and receiver, you will see that the pins and holes on the plug are low on the plug and not in the middle like you might assume. So look at the receiver and match the plug. Make sure you put foam around the receiver.
#212
Hi guys, did the new 13T Input Bevel Gear (HB204439) in D819/819rs can be replaced by Mugen or Kyosho 13T Pinion gears for MBX8/mp9/mp10? Or another brands such as SWORKZ?
#215
Does the D819 enginemount fit a D817 without the adjusters ??
#216
Hi what about the durability of D819? And what’s part is most to break? Thanks
#217
I'd keep shock pins handy ( easy to lose ), Arms (because why not ), hex pins, and shock stand offs (I've broken a couple), and end links.
#218
Car is super solid. On the E817 and D819 I've only ever broke a shock stand off and end link on the E817 (same time). Never broken anything on the D819.
#219
Hi all, when setting my rear droop with the lowest hub position inserts and 129 shock length the right side driveshaft(uni joint) is touching the arm, inserts are all correct and kit is new from absolute
#221
What's the part number for 2.5 D block?
#223
I run my camber link on the inner hole on the front hubs,what difference does it make when you run the link on the other 2 holes.
#224
I feel the middle to outer hole can be run on 90% of the tracks in Texas. Every so often on really tight tracks I find I need the inner most hole to get really fast , crisp steering.
I highly suggest you try all the positions so you know the feel it makes. Of course remember to reset your front camber and toe after you so this .
#225
Has anyone tried carbon fiber shock towers, if so how do they hold up compared to stock towers?
