HB Racing D819 Nitro Buggy
#182
No car is perfect...but I have not driven a car that is this easy to drive and you can feel the setup changes right away after making them. Only thing I don't like is the toe blocks rubbing as we have some hard tracks here, and you have to change them and the chassis often. Other than that gear boxes, diff gears and plastics all hold up very well.
#184
Thanks for adding that update. I was wondering what was going on with the D819 kits out of stock everywhere.
#185
Regarding the RS version,
Does shortening the chassis by 2mm bring the chassis to the same length as the 817?
What's the advantage they are trying to gain by shortening by 2mm?
Do the diff input gears need revising?
#186
e817/e817v2 is 4mm shorter then d817/D819
D819RS is the same length as e819 now
so the e819 is 2mm longer then e817/v2
There’s a live video on hb Facebook of ronnefalk talking about car.
he said the gears don’t wear as fast cause more contact patch on gears.
#187
Thanks, jersey - appreciate the detailed response.
#188
How is different between 43/13?And if i like to try 43/10 what's spur and clutch bell should i run with?I lookking at 0.8 module 17/60..Any idea?I'm running stock 43/10 in my E817...My EP car is very easy to drive..so that's why i would like to try on my Nitro car😊
#190
Found M2C zero rebound emulsion caps. Not sure if I'll get to the track this weekend but I'll let you know how they did when I do. They feel great in hand.
#191
#192
Hi do you have size of the rx battery box ??? Wich one do you use ???l
#193
I use this one. Fits just fine.
https://www.amainhobbies.com/protek-...k-5162/p233427
Supposed to use this one.
https://www.amainhobbies.com/protek-...k-5171/p188054
#194
Thanks 😉😉😉
