HB Racing D819 Nitro Buggy >
Like Tree110Likes
Old 05-20-2019, 10:42 AM
  #151
Big Will's Avatar
How do we run emulsion on this car? Is there an o-ring? Or are we to cut the bladder?
Big Will is offline
Old 05-20-2019, 07:53 PM
  #152
Trader Rating: 50 (100%+)
Yes, just cut off the billow part and good to go.
GettinLapped is offline
Old 06-07-2019, 03:20 AM
  #153
Anybody running OS B2103 type R with the stock mount? Cracked my crankcase with the new mount.. Didnt have any problem using my b2102 and motor was fine mounted on diff buggy... just curious..
luihed is offline
Old 06-07-2019, 07:59 AM
  #154
samuelsonmark71's Avatar
Trader Rating: 22 (100%+)
I prefer to just run the old mount
samuelsonmark71 is offline
Old 06-07-2019, 11:34 PM
  #155
Yes, using the old mount now..
Buggy is awesome, jumps way way better than my tki4 and best of all I can finish a 45min main...
luihed is offline
Old 06-08-2019, 12:38 PM
  #156
Have anyone tried MIP Bypass1 piston?
artur72 is offline
Old 07-12-2019, 06:00 PM
  #157
Lightbulb
HB204565 D819 Arm Mount C (Wide)
HB204562 D819 Servo Saver Tube
D819 Editable Blank Setup Sheet
TRiN is offline
Old 08-11-2019, 12:51 PM
  #158
I'm switching over to the new Engine Mount and the Engine Mount Cams. I run the Mod 0.8 Gears. What Cams do I need to use with this setup to get the proper gear mesh?. I guess there are three types, so just trying to figure out which one works. Also, what's the proper orientation of the notch in the Cam as far as facing inward or outward on the chassis in order to accomplish the gear mesh?. Thanks in advance.
kaneye2 is offline
Old 08-12-2019, 04:27 PM
  #159
TruggyStyle's Avatar
I think there is no general Cam set for the same gearing every time. It depends on your Motor and the Crankshaft height.
Normally one position on the Cams is for new gears and the other one for broken in gears. In my case with a OS 21B AD it didn’t work. With stock 13/48 gearing I need the no.2 cams and not the no.1 of the kit. I bought all of them to get the best gearmash with every Engine and gearing.
TruggyStyle is offline
Old 08-12-2019, 09:35 PM
  #160
Thank you for your input. I've tried all three Cam sets, and it feels as if the #3 Cam set is the one that works for me. The gear mesh feels a little tight and notchy, but I was told that if I run it this way for about two tanks it will eventually free up.
kaneye2 is offline
Old 08-24-2019, 03:49 AM
  #161
So -2mm chassis? Isn't that an 815 chassis?
brokenmoto is offline
Old 08-26-2019, 01:26 PM
  #162
The current chassis is 4mm longer than the original 815 chassis so it will be 2mm longer.
brokenmoto likes this.
Dave.C is offline
Old 08-28-2019, 05:24 PM
  #163
What is different about the 819 servo saver tube?
fbrk8r is offline
Old 09-03-2019, 09:29 AM
  #164
omarwashington's Avatar
About those rear hub inserts manual says to have arrows pointing away from each other but I've seen other people's car have the arrows pointing The same directions. Kinda confused but ive built my rear hub inserts per manual.
omarwashington is offline
Old 09-03-2019, 10:06 AM
  #165
both pointing out equals no toe and wide wheel base
both point in equals no toe and narrow wheel base.
Front one pointing in and back one pointing out equals more toe in.
Front one pointing out and back one pointing in equals less toe in.
Flipnsticks is offline
