Shock oil
Shock oil
Hi all
What would be a general weight shock oil to use in front and rear shocks for general all round usage.
Thank you
Thank you
The choice is made based on the temperature and the piston that is used.
If you're just bashing (seems like it), 40w front & 35w rear should be good enough regardless of what piston you're running. It might be a little stiff, but will work better on jumps.
Thanks guys for the responses. Will try 40 front and 35 rear and go from there.
