Official Kyosho MP10 Thread >
Like Tree29Likes
Old 12-19-2018, 07:53 PM
  #61
RMKinWI's Avatar
Trader Rating: 15 (100%+)
33015B INFERNO MP10 Kit
maddog9 likes this.
RMKinWI is offline
Old 12-20-2018, 12:31 AM
  #62
Some of the comments on this thread are hysterical and read as though they're coming from a 9-time IFMAR World Champion 1/8-scale buggy design engineer.
Kanai has 8 though, which is the most ever, so entertainingly enough I know that's not the case.
mtbkym01 and 305M3 like this.
stephen_bess is offline
Old 12-20-2018, 12:59 AM
  #63
banana rt's Avatar
I wish they will be the winner for the next IFMAR,
signing as many top drivers as they can.
banana rt is offline
Old 12-20-2018, 04:10 AM
  #64
Def more changes and improvements than the manual initially led me on to. Happy to see that. This seems likely a pre order for me
mlax is offline
Old 12-20-2018, 05:24 AM
  #65
Hi guys.
Can someone please tell me how itís possible to use the outer holes on the susp arms, without loosing droop ?
what parts do i need for my TKI4 to do the same? Cant figure it out since itís not the MS (50mm) front dampers. Itís expained in this thread without me understanding.
ColourGhost is offline
Old 12-20-2018, 05:41 AM
  #66
Wonder if you can use the same starter box settings to hit the fly wheel?
jkurz211 is offline
Old 12-20-2018, 05:48 AM
  #67
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by ColourGhost View Post
Hi guys.
Yeah, I'm not sure how they achieved that. Having owned the MP9 tki3 in the past, you pretty much had no droop if you used the outer holes in the a arms. If I had to guess, I'd bet they lowered the shock towers mounts to achieve the added downtravel but what do I know.
The car looks great imo....
symmetricon is offline
Old 12-20-2018, 05:57 AM
  #68
Tigergutt is offline
Old 12-20-2018, 06:24 AM
  #69
1/8 IC Fan's Avatar
Trader Rating: 76 (99%+)
Nice to see they added the aero side pods as pioneered by Delta in Italy. Should make it a bit more popular with the European drivers.
1/8 IC Fan is offline
Old 12-20-2018, 08:43 AM
  #70
Originally Posted by Payton 34 View Post
It appears that the CG has been moved forward. If you look at the front center universal it is 2mm shorter, and the rear center universal is 6mm longer than the MP9. Depending on other design features this would potentially move the center diff assembly and motor further forward on the chassis. If true, this is probably the biggest single game changer between the MP9 and MP10. This should provide more steering. This is also why a new chassis part number was required.
I agree with you. This is the biggest change. The MP9e Evo moved the CG forward and that thing turns on a dime.
Arcain41 is offline
Old 12-20-2018, 10:16 AM
  #71
I really like how the evo drives. I didnít realize it had a more forward weight bias because it seems more hooked up in the rear than the nitro car and no loss in steering.
windellmc is offline
Old 12-20-2018, 08:19 PM
  #72
Matty A is offline
Old 12-21-2018, 02:22 AM
  #73
"The widely updated suspension offers offset bushing inserts for easy wheelbase and toe angle changes and increased durability and stability was achieved by utilising 4.5mm diameter hinge pins. In addition the rear suspension mounts are 5mm wider, moving the shock mounting position further out on the rear arms, allowing to use softer shock oils for less performance fading during temperatures changes."
That's actually a a substantial change to the car. Also, from the photos, the car looks to have much more rear droop...
The rear pivot is wider for shock temperatures? I'd like to see the physics on that on. For equivalent damping the same amount of energy needs to be managed.
AntH3000 is offline
Old 12-21-2018, 04:18 AM
  #74
By widening the rear pivot they increased the rear roll stiffness. My guess is the lower shock mounting holes also moved out a little bit too, that would give the arm less advantage against the shock meaning the shock can be softer.
At at least thatís how I read the press release.
CedarCityJohnny is offline
Old 12-21-2018, 10:20 AM
  #75
Does anyone have an idea on when these kits will be shipping out?
shark2288 is offline
