Official Kyosho MP10 Thread >
Like Tree68Likes
Old 03-13-2019, 12:06 PM
  #316
Are the screw nuts for shock mounts and steering knuckle ends 5.5mm? for MP9 mp10 cars?
sn47som1 is offline
Old 03-13-2019, 12:10 PM
  #317
[QUOTE=am;15412955]
Originally Posted by 1/8 IC Fan View Post
Thats pretty spot on, just ask Mark Pavidis after he won the worlds, with his Fioroni modded car, even his shocks and chassis were Fioroni....
From Neobuggy:
All the fironiparts on that car has the same geometry as you could buy from Kyosho. It was made for looks and some weightsavings. Unless you were at a VERY highgrip track, thoose center chassisbraces made the car alot worse to drive...I sold quite alot of Fioroni here in Norway at a point. Some of the Fioroni chassis tough, had some changes to the rear end. It was longer. It fixed the MP777 loose rear end.
The quality is higher with Fioroni compared to the factory parts. I am building a Fioroni psm lunsford modded buggy right now cant wait to finish it tons of factory parts to uninstall and install the aftermarket. I am using the spring flex chassis mounts I hope they're better than the stiff ones you didn't like. (tki4 build) I went with the T works tki4 chassis to test. I love the fioroni chassis but wanted to try something new and also has the clutch bell cut out!
sn47som1 is offline
Old 03-13-2019, 03:21 PM
  #318
Originally Posted by Mickey_B View Post
on on another note,why doesnít Kyosho come out with a split center diff. Seems pretty standard now days.
i think Mugen ditched their split center diff when they went to the mbx7. That is a pretty popular car without a split diff mount.
windellmc is offline
Old 03-13-2019, 05:14 PM
  #319
Mickey_B's Avatar
Trader Rating: 5 (86%+)
oh man, you got me on that one.
Mickey_B is offline
Old 03-14-2019, 08:14 AM
  #320
At the rate the mbx5 went through oil it needed a fast way to get to the diffs. The 6 was better about it so I can see why Mugen thought it was unnecessary in the 7. The kyosho never had this problem. The best part about a split center diff is not having to fight the brake linkage so much.
Old Yesterday, 11:48 PM
  #321
My Kyosho Brothers,
is there a one piece mount out yet for the MP10? Iím currently using the T-works one piece mount on my TKI4 and lifeís so easy with it.
91junior is offline
