Kyosho MP10 Thread
#992
They got me with their clutch tool to measure wear to.
https://img2.associatedelectrics.com...utch-Gauge.pdf
#994
Mip pistons
Has anyone used the 6 hole Mip pistons and if you have would you share your shock and spring set up for low traction bumpy outdoor tracks thank you in advance
#995
any mp10s for sale? I have a NB48 2.0/2.1 with 90% of the updates and full S&S set up. Willing to trade, comes with 3-4 gallon sized zip locks full of NIP parts
#997
Hi guys, are the longer shock towers and shocks a big improvement on the MP-10? I’m feeling undecided if it’s worth the money to upgrade them. I run a on pretty blown and bumpy track.. any advice would be great! I have already put on the longer rear standoffs, and I’m using red springs in the rear.
#998
Building a new tki2 and I'm coming from serpent, curious if there are any tips for the build process?
#999
I’m building the shocks, is there a guide or measurement to check for shock length once they are built? Or just tighten the plastic ball end all the way?
#1000
#1002
It seems as if they are discontinued now, maybe they can be special ordered. Typically your best bet is to call Kyosho America or which ever continent you are in. They are usually helpful and can get the info you need on the spot. I personally just died some white ones green and pink and it is very effective so far. (rit clothing die)
#1004
Random question sorry, but has anyone ever tried to use a different brand center diff mount, was hoping for something that has a split for easier access.wasnt sure if any aftermarket ones or another brand that might fit.
Cheers
Ryan
Cheers
Ryan
#1005
https://www.absolutehobbyz.com/m2c-r...iff-mount.html
